Old 11-28-2021, 03:17 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Diff mounts
Whiteline and their “only minimum force needed” to remove the oem mount lol anyone has a method you’ve done to remove mount
IsaiahW is offline   Reply With Quote
Old 11-28-2021, 07:28 PM   #2
Code Monkey
Drives: Subaru BRZ
Do not use these bushings, they are trash.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
MrSkubi (11-29-2021)
Old 11-29-2021, 09:52 AM   #3
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Looks like they were probably installed incorrectly, or you had a defect. I've been using them for 2 years now no issues.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Trueweltall (11-29-2021)
Old 11-29-2021, 10:03 AM   #4
Spawn_Of_Creation
Human
penetrating oil/spray and lubricant. Support the diff with a jack when you remove the mounts.
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 04:43 AM
what trans and diff mounts to get Pho20 Engine, Exhaust, Transmission 10 09-13-2017 10:56 AM
PBM Solid Diff and Subframe mounts install Thebadvibes__ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-23-2017 02:04 AM
Solid diff mounts sosick Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-05-2013 12:04 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 03:11 PM
