Old 11-27-2021, 06:29 PM   #1
donour
Drives: frs
Raceseng rear tophat bolts
Dear internet brain trust:
Does anybody know if the Raceseng rear top hat bolts are threaded or pressed it? One of mine got an accidental dose of too much hurry.
donour is offline   Reply With Quote
Old 11-27-2021, 07:44 PM   #2
strat61caster
strat61caster's Avatar
iirc if you flip it over and see a hex key you can unthread it, might be worth filing down the bolt a little so you don't damage the threads in the top hat when taking it apart.
ineedyourdiddly
Old 11-27-2021, 07:50 PM   #3
donour
Drives: frs
I tried that. I didn't want to put TOO much torque on it and -- as mentioned --make things worse. Are we sure it's threaded?
Old 11-27-2021, 09:17 PM   #4
Joon525
Joon525's Avatar
Drives: 2016 BRZ
They look threaded to me.
https://raceseng.com/shock-top-rear-...-brz-2013-719#
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
whataboutbob (11-27-2021)
Old 11-27-2021, 11:38 PM   #5
donour
Drives: frs
Originally Posted by Joon525 View Post
Roger that. It required way more torque than I expected to get loose: 150-200 ft lbs. All is good.
It is an M10-1.5, so I had machine screws already that were an exact match. Disaster averted.
The Following 4 Users Say Thank You to donour For This Useful Post:
EAGLE5 (11-28-2021), Jdmjunkie (11-28-2021), strat61caster (11-29-2021), whataboutbob (11-27-2021)
Old 11-29-2021, 02:01 PM   #6
donour
Drives: frs
Update: Got a message back from Raceseng too. The bolts had threadlocker, which I didn't see when I took them off, but explains the required disassembly torque.
The Following User Says Thank You to donour For This Useful Post:
FS: Raceseng 2" rear shock mounts and EBC Yellowstuff rear pads captain awesome Brakes, Suspension, Chassis 5 12-15-2020 02:37 PM
SOLD: Raceseng Cas Camber Front Top Mounts Fortune Autos Bolts AustinTCLN Brakes, Suspension, Chassis 5 09-25-2017 10:53 AM
TopHat Issue St Coilovers drew_kar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-07-2017 09:21 PM
FS: Racer X Rear LCA, Hotchkiss Front Bar, Raceseng 1" Rear Drop Mounts Kuro86 Brakes, Suspension, Chassis 4 07-26-2017 03:01 AM
FS MA: RCE Tarmac 2 with OEM tophat, $1650 dreamwonder Brakes, Suspension, Chassis 8 08-09-2016 07:43 AM
