Old 11-18-2021, 05:29 AM   #1
innocentguy
Person
Drives: GT86
Retune after going back to stock fatback?
Hey everyone. I have a full exhaust system with a dyno tune on the car and I want to go back to the stock catback system because the car is way too loud. Would I need to retune it if i chuck the stock catback back on the car?
innocentguy is offline   Reply With Quote
Old 11-18-2021, 06:09 AM   #2
SydBRZ
SydBRZ's Avatar
Drives: MY14 BRZ, MY06 WRX
Are you NA? If you're only changing from the cat back, I wouldn't worry too much.
Maybe log a bit if you're able, and make sure you're not suddenly seeing anything weird in terms of knock or timing being pulled.
If you said you were changing back to stock headers and frontpipe, I'd say definitely get it re-mapped.
If those parts are staying as is, or have been stock all along, your tune probably won't change much just by swapping out the cat back.
If you're forced induction, throw everything I said out the window - if you're changing your cat back on a turbo/SC tune, get it remapped/checked.
SydBRZ is offline   Reply With Quote
The Following User Says Thank You to SydBRZ For This Useful Post:
tomm.brz (11-18-2021)
Old 11-18-2021, 01:04 PM   #3
innocentguy
Person
Drives: GT86
Yeah the car is NA
Old 11-18-2021, 01:44 PM   #4
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
just load your stock tune.
Old 11-19-2021, 11:55 PM   #5
jflogerzi
jflogerzi's Avatar
Are you changing the headers or FP? If all your doing is changing the Mid pipe and muffler no re-tune is needed.
2013 Series 10 FRS #553
Old 11-20-2021, 12:12 AM   #6
innocentguy
Person
Drives: GT86
Yeah just the midpipe and muffler will be going back to stock. I will be leaving the catless header, overpipe and high flow catted front pipe.
Old 11-20-2021, 12:18 AM   #7
jflogerzi
jflogerzi's Avatar
You golden then. No re-tune needed at all.
The Following User Says Thank You to jflogerzi For This Useful Post:
jcw99 (11-21-2021)
Old 11-20-2021, 04:36 PM   #8
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I agree Tune should be OK.
gen3v8 is offline   Reply With Quote
Retune needed for pulley change? Deep Six Software Tuning 6 11-03-2017 09:39 AM
Borla EL header exhaust leak/Will I need a retune TelMinz Engine, Exhaust, Transmission 9 06-12-2016 06:10 PM
FS: Dell Venue Pro 8 with Win. 8.1 Full. Tune, log, retune, FAST Flashes Sportsguy83 Engine, Exhaust, Bolt-Ons 5 06-02-2014 06:27 PM
?!?!?!? Diffuser with SRT fatback ?!?!?! sweetfrs Cosmetic Modification (Interior/Exterior/Lighting) 4 04-13-2014 11:09 PM
stg1 custom tune add intake retune =??? StormTrooper Engine, Exhaust, Transmission 11 12-23-2013 05:59 PM
