Old 11-14-2021, 09:38 AM   #1
xyrodon
Drives: 2015 FRS
Oil leak after wheel bearing repair
Morning all,
I own a 2015 FRS with lots of mileage, over 200,000 km. My wheel bearing were very noisy so they were repaired at iGarage in Markham. Right after I got my car, it's been leaking oil like crazy. Any ideas or suggestion on the severity of this issue?
xyrodon is offline   Reply With Quote
Old 11-14-2021, 09:42 AM   #2
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Have you taken it back to have them look at it?
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
Old 11-14-2021, 11:28 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
My childhood dog was put down after I graduated. Does that make it the schools fault for allowing me to graduate?
x808drifter (11-15-2021)
Old 11-14-2021, 11:29 AM   #4
Petah78
Drives: 2022 BRZ sport-tech
Normally speaking, a wheel bearing repair/replacement should not have anything to do with oil leaks, not that i can think of anyways.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 11-14-2021, 11:40 AM   #5
soundman98
soundman98's Avatar
But then, I've never had a 200k km vehicle that didn't leak something all the time.
Old 11-14-2021, 03:17 PM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
We're not talking about a rear wheel bearing and a diff oil leak are we???
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Ultramaroon (11-14-2021)
Old 11-14-2021, 03:33 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
OP, are you saying it didn't leak at all when you took it in for the wheel bearing, and now it leaks like crazy? Like others have asked, from where is it leaking. If it's NOT the engine, then don't drive it back. Have it trailered because the transmission and diff don't have a convenient way to check oil level. If it's from the engine, then as long as you know there's oil on the dipstick, and it sounds normal, it's probably safe to drive a short distance.
Old 11-14-2021, 07:24 PM   #8
xyrodon
Drives: 2015 FRS
Hi,
Thanks for your replies. It is from the engine. The guy I take it to is in Markham, I'm in Mississauga. I took it to him as many on this forum liked him. I am taking it to a dealership tomorrow in Milton, I know the manager very well there and it's closer to me.
For the record, I baby this FRS as it's my only car. Yes it is at 211,000 km but the only issues I had with it until now were noisy wheel bearing, which were just fixed. Other than that, it's the usual - brake, oil changes, spark plug change, etc. I always oil change it 1000 km before it's due and only put premium in it.
So after this guy at IGarage repaired it I am surprised to see a leak.
Old 11-14-2021, 09:24 PM   #9
Ultramaroon
not playing cards
Might sound like an odd question but is the oil pan rusty? Did someone maybe pick at the oil pan while it was on the lift? @villainous_frx, amirite?
Old 11-14-2021, 09:33 PM   #10
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
my elbows hurt just thinking about replacing an oil pan again.
PTSD to this summer...
https://www.ft86club.com/forums/show...7&postcount=51
villainous_frx is online now   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
Tcoat (11-15-2021), Ultramaroon (11-14-2021)
Old 11-14-2021, 10:16 PM   #11
Ultramaroon
not playing cards
Just trying to think of a reason why it would suddenly leak oil "like crazy."
Old 11-14-2021, 10:32 PM   #12
villainous_frx
Off to the track!
Yep, I had a pin hole leak in the pan. I think the cause was when I jacked up the engine via the pan (as everyone suggests), the pan was already weak from corrosion and the block of wood I was using poked through at the edge/corner.
Other places for common oil leaks would be: cam covers, valve cover gaskets, timing cover, the rear block off plate thing, and easiest to check... the oil drain plug
The Following User Says Thank You to villainous_frx For This Useful Post:
Old 11-15-2021, 12:24 AM   #13
soundman98
soundman98's Avatar
and zero of those things would be effected in any way by changing a wheel bearing.
Ultramaroon (11-15-2021)
Old 11-15-2021, 01:12 AM   #14
villainous_frx
Off to the track!
oh absolutely, but you know how those shops are... causing random oil leaks that only THEY could have done
The Following 5 Users Say Thank You to villainous_frx For This Useful Post:
bcj (11-15-2021), Busybee (11-15-2021), FLIPDADY (11-16-2021), soundman98 (11-15-2021), Ultramaroon (11-15-2021)
Any 3 piece wheel shop repair suggestions or wheel repair shops? kyle116 Southern California 7 07-24-2021 12:55 AM
Cam Plate Leak Repair Extreme86 DIY (Do-It-Yourself) Guides 52 06-14-2020 11:13 AM
Repair shop in LA - Clutch Throw out bearing Octoman Southern California 18 09-06-2016 04:45 PM
Oil Leak Video | Repair Dezoris Issues | Warranty | Recalls / TSB 6 02-26-2014 11:43 AM
OIL LEAK REPAIR | FRS BRZ JPxM0Dz Engine, Exhaust, Transmission 1 02-20-2014 10:12 AM
