Old 11-12-2021, 10:15 AM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Consequences?
I’ll be installing an Edelbrock S/C on my otherwise stock engine soon. A CSG stage 1 tune will be used.
What would be the consequence of tuning for 94 octane fuel but having to use 91 octane in a pinch? 94 can be hard to find in rural (northern) areas of Ontario.
91 would just be a stopgap until finding a 94 station and only during street driving. Not on track.
Thanks in advance for your constructive responses.
Muskoka800 is offline   Reply With Quote
Old 11-12-2021, 11:51 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It could knock, in response the ECU will pull timing and drop IAM.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (05-01-2022)
Old 11-12-2021, 01:19 PM   #3
tomm.brz
Drives: brz 2017 hksv2
it WILL knock, lot of times
With ecutek you get 4 different ignition tables and maps, get your car e-tuned for 91 oct
The Following User Says Thank You to tomm.brz For This Useful Post:
Wally86 (11-16-2021)
Old 11-14-2021, 11:35 AM   #4
Hurricane Nate
Drives: 2020 BRZ (Black)
Talk to the guys at CSG about it. Speaking from personal experience, they are very responsive to inputs from you during the process of e-tuning your engine, and they’ll give you great feedback on what they think will be a best fit for you and your engine.
Hurricane Nate is offline   Reply With Quote
Old 11-14-2021, 02:35 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If your tuning with ecutek just have the tuner give you a safe 91oct map. You can change maps while driving via the cruise control stalk. Let your default tune be map 1 and your low performance map for the other one. If you ever put 91 in the car- switch maps and a never worry again.
The Following User Says Thank You to Kiske For This Useful Post:
RedReplicant (05-06-2022)
Old 11-14-2021, 07:33 PM   #6
jflogerzi
jflogerzi's Avatar
as others have said get a safe map for when on 91 and switch to it as needed.
2013 Series 10 FRS #553
Old 11-15-2021, 10:34 AM   #7
Muskoka800
Thanks all!
I will discuss the dual map option with my CSG tuner.
If it’s as simple as a stroke of the cruise control switch, I’m in.
Old 04-18-2022, 01:08 PM   #8
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Old thread, but couldn't you just keep a bottle of octane booster in the truck for those times?
LRNAD90 is offline   Reply With Quote
Old 04-18-2022, 01:47 PM   #9
tomm.brz
Depends on which bottle you mean, it must be something that works like bardhal bsf
Also would be wise to make a map using normal fuel + this booster and retune with that
Old 04-18-2022, 06:51 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
That and pickled garlic.
Old 05-01-2022, 10:57 AM   #11
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I don't know if this is relevant, but my Porsche-Club group ran Mosport once and were all about to fill up on 91, which was all we could find. A local guy came by and hipped us to where we could get 93. The only guy who missed the tip filled his 944 Porsche turbo with 91 and burned a valve. He had to take it back to the states on a trailer.
Qwimby1 is offline   Reply With Quote
Consequences & experiences with bad break in periods? Kerune BRZ First-Gen (2012+) — General Topics 19 03-30-2015 03:05 AM
Consequences of backing out of an order? Dzeremijs BRZ First-Gen (2012+) — General Topics 8 07-11-2012 05:51 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 12:52 AM
