Old 11-07-2021, 05:52 PM   #1
alphasaur
friendly
Drives: 17' 86
bypass front tweeters/dash speakers
Hello!
Currently running a kw750bt, I have polk audio DB651s in the doors, a 10" rockford fosgate sub in the trunk. Amp is a pioneer 4 channel with 2 channels bridged for the sub. Wired using the stock wiring harness.
I'd like to get better highs and mids now, would I be best off running rca from the deck front rca output jacks to the amp vs running it from the stock harness and then just unplug the dash speakers?
Then I could just run the door speakers in 2 way?
I'm pretty new to car audio so I need some patience. thank you!
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-07-2021, 06:29 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by alphasaur View Post
Hello!
need more details as to what this means.
Old 11-07-2021, 09:09 PM   #3
alphasaur
friendly
Drives: 17' 86
Gotcha,
https://www.crutchfield.com/S-uguFbA...gaAmrJEALw_wcB
this amp with 2 channels wired to the door speakers
and 2 channels bridged for the 10" rockford sub.
I'm using the stock amp wiring harness as per this thread:
https://www.ft86club.com/forums/showthread.php?t=42239
White and grey wires are going to RCAs for input.
Old 11-08-2021, 09:19 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Door speakers aren't guaranteed to be an improvement... Not that the stock setup is great, but the placement is pretty good.
That said, the system may be unbalanced now if the output levels weren't matched.
Lots of ways to build a system. It takes more than random parts and some wiring.
Old 11-08-2021, 10:34 PM   #5
soundman98
soundman98's Avatar
Gotcha,
beware, that amplifier is drastically different from other amplifiers. while that specific amp will accept speaker-level and low-level inputs on the same rca connector, most won't and you risk damaging any other amp doing the same thing if you were to get a different amp for any reason.
your power wire is incorrect.
you need to install a 4 gauge amplifier power kit, wired to the battery, and with a new ground first.
you're 'strangling' the amp by giving it such a small power lead. get that changed first, and then reevaluate the setup. it will likely sound much better.
Old 11-08-2021, 11:44 PM   #6
alphasaur
friendly
Drives: 17' 86
Oh, I should have mentioned I am not running power from the stock amp harness. I am running an 8 gauge kit at the recommendation of crutchfield.
The speaker wires from the harness are low level, yes? That was my impression.
Old 11-08-2021, 11:49 PM   #7
soundman98
soundman98's Avatar
that's better.
to change the tweeters, you'll need at least this harness. otherwise, disconnecting the oem tweeters will kill the amp input.
https://smile.amazon.com/RED-WOLF-20...6433281&sr=8-3
you can try adding on a set of aftermarket tweeters to that wiring harness, but you might need to run wire off the amp's speaker outputs to get a more even sound.
Changing the front dash speakers / door speakers jeffs42885 Electronics | Audio | NAV | Infotainment 8 06-21-2020 06:35 PM
dash speakers (tweeters) steveng3191 Electronics | Audio | NAV | Infotainment 11 08-21-2017 05:04 PM
Help I need to bypass the factory amp. the powers the door speakers for my BRZ. zoth Electronics | Audio | NAV | Infotainment 1 04-26-2014 07:14 AM
Would coaxial door speakers plus stock tweeters be too much high frequency sound? Prog Electronics | Audio | NAV | Infotainment 4 12-27-2013 07:15 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
