Old 10-31-2021, 12:46 PM   #1
Zeno301
Drives: 2019 Subaru Brz Series Grey
Need help identifying what this connector is for.
Installing an aftermarket headunit and I'm trying to make sure I get all the adapters necessary and I have all of them but I'm not sure what this last connector's function is. It is a 10 pin connector.
I tried searching but couldn't find much for a diagram on a 2019 brz headunit.
Any help would be appreciated.
Edit: I also need help identifying what the grey connection is for.
Zeno301 is offline   Reply With Quote
Old 10-31-2021, 02:41 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
better question is what do you need it for?
the gray connector ought to be the oem satellite radio antenna.
Old 10-31-2021, 02:48 PM   #3
Zeno301
Thats what I'm trying to figure out. Not sure if its something I'm going to need to tap into or find an adapter that will let me plug it into the aftermarket headunit.
My car is in the shop getting some dents fixed, otherwise I would have the new headunit installed and would know if I needed it or not. Just figured I'd find out now and order any parts I may need before I get the car back.
Old 10-31-2021, 05:58 PM   #4
soundman98
soundman98's Avatar
shouldn't really need anything more than the standard harnesses. the metra 70-1761 will get you power and speaker connections.
they list 40-lx11, 40-lx21, and 40-lx31 for terrestrial radio antenna's, i used just the 40-lx11 in my '14.
they don't actually list anything for backup camera integration, but i believe the toyota-compatible axbuch-t36v would be the harness and 6v adapter needed.
Need help identifying r&p set BenL Engine, Exhaust, Transmission 3 03-03-2020 11:09 AM
HELP! need help identifying wheels olsonpg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-06-2019 08:00 PM
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
Help identifying picture WelshJ Scion FR-S / Toyota 86 GT86 General Forum 11 01-17-2014 05:12 PM
Need help identifying a car! kALMIGHTY Off-Topic Lounge [WARNING: NO POLITICS] 15 09-28-2013 04:35 AM
