Drives: 2013 Scion FRS
![]() I'm at around 3 months of ownership and I'm close to just giving up on this platform. i posted a thread a while ago discussing the engine failure I was experiencing within the first month of purchasing. this required a new short block and oil pan. -------------------------------------------------------------------------------------- SINCE the installation of the new short block I've experienced a slew of new problems listed out here: 1) dealership rewired in the VIPER remote start incorrectly, causing the main fuse to blow, leaving me stranded, twice. 2) experiencing an audible and smell-able gas leak after turning the car off 3) as a result of trying to diagnose and repair the gas leak, I'm now dealing with rough idling and intermittent loss of gas pedal response ![]() __________________________________________________ __________ what I know : -the leak is coming from, the hose located under the bottom left hose of the intake manifold __________________________________________________ ___________ what was attempted: -got a mobile mechanic to come out and try to diagnose/fix the leak -disconnected all intake hoses -disconnected negative battery terminal -disconnected ECU -disconnected the fuel line covers to gain access to the area leak appears to be coming from. -disconnected throttle body - removed bolts holding the intake manifold down __________________________________________________ ___________ what leads to the nightmare situation I find myself in: at about 7 hours into the job, my mechanic, with everything described above disconnected and removed, jumps up and goes "OH SHIT I FORGOT MY SON HAS A DOCTORS APPOINTMENT!!" and just leaves. this was 2 days ago and last I heard from him, he's 2 states away, with my obd2 scanner, doing a different job. ![]() __________________________________________________ ___________ SO... my brother and i did our best to get everything reconnected, and to our credit, the thing starts, runs (kinda), and turns off ALL WITHOUT CATCHING ON FIRE (i consider this a win) ((my wife does not)) ![]() __________________________________________________ ___________ I now have a car that bounces between 1-2k rpms at idle, randomly loses power and/ or gas pedal response, and is overall, a gigantic fucking headache. I'm going to buy a new scanner in the morning and will update with specific codes. any advice for solutions? I'm at my wits end with this car and I just need to get it functioning again and really don't have the resources to pay another $8,000 to Atlanta Toyota to have it "fixed" again. any help is appreciated and i hope you are all having a better day than I am |
Drives: BLue 2013 frs
Codes will be the best start. AND, was that leak under the intake manifold ever addressed when it was put back together?
The codes im getting are:
C1201 C1231 C1234 C1294 U0073 U0100 U0101 Sent from my iPhone using Tapatalk |
Just remembered I never closed this thread out, turns out the leak was from a bad injector. And the slew of codes I got thrown was from not tightening down an ECU amounting bolt enough. Tightened it down and thing ran perfectly
#6 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
The real question remains, did the mechanic come back and return your scanner??
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#7 | |
Found out a few months back he’s in prison now. Cut my losses, bought new scanner ![]() Sent from my iPhone using Tapatalk |
| Tags |
| repair |
| 2013 Gas Cap Leak ? | Helturus | Issues | Warranty | Recalls / TSB | 6 | 03-06-2020 10:35 AM |
| 2013 BRZ Oil Leak | yablonskiy11 | Issues | Warranty | Recalls / TSB | 5 | 03-23-2019 01:46 PM |
| Can't Turn After Wreck Repairs | Strife26 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 02-26-2019 06:44 PM |
| Argh - spotted the dreaded OIL LEAK on my 2013 BRZ | exE36M3 | Northern California | 0 | 01-24-2016 05:24 PM |
| Looking for a place to get repairs done | discretion | Mid-Atlantic | 1 | 11-28-2015 05:38 PM |
