Old 10-22-2021, 12:05 PM   #1
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Exclamation Losing traction for no reason?
I know people have posted about similar issues but everyone is running different setups so I figured I’d post my personal situation
Disclaimer: suspension is stock and im running 215/45/17s for my tires; same as stock. I recently got my brakes serviced and they replaced my tires too so they aren’t Michelin’s or anything fancy, but I’ve been having this problem for weeks now even before I got new tires.
So when I’m cornering, whether taking a corner hard or literally just going 25-30 mph, I’ll notice my traction light will come on and I’ll slide a bit. It seems like the back is kicking out so I’m not sure if that’s oversteer or understeer but that’s what’s happening. I usually notice it happens when I’m taking corners towards the left but I think it sometimes happens when the curves are going to the right. In the past I was able to take corners smoothly but now it seems like I really need to be careful otherwise I could spin out.
I suspect suspension issues but when I went to a shop about it they said everything was fine.. but they lied about my brakes being fine when in fact they were dog shit and i knew that beforehand so who knows what else they lied about 🤷*♀️
I also notice that sometimes when I’m going highway speeds it feels like my car is shaking/it feels like it’s swaying back and forth somewhere under my car. (if that makes sense) Could these issues be related?
Thanks always for any responses 😆 Trying to figure out if I have a real issue or not.
julzbrz is offline   Reply With Quote
Old 10-22-2021, 12:51 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
What tires? All 4 the same tire?
dragoontwo is offline   Reply With Quote
Old 10-22-2021, 01:10 PM   #3
Get your alignment checked. Not just a visual inspection but actually checked.
BigTuna (10-22-2021), Dadhawk (10-26-2021), ScoobsMcGee (10-29-2021)
Old 10-22-2021, 04:55 PM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
This.
BigTuna is offline   Reply With Quote
Old 10-22-2021, 05:23 PM   #5
Grady
Grady's Avatar
What tires did the put on? They may have put shit tires on.
Old 10-22-2021, 07:13 PM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
I had a similar issue. Ball joint. I'd get another shop to check your car.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 10-22-2021, 08:27 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
tire specs are important, as they could be contributing to the final result, but the real problem is your alignment.
get it put on an alignment jig, get it straightened out, and be sure to get a printout of the before/after alignment settings.
Old 10-22-2021, 09:43 PM   #8
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
sorry i forgot to note that they only changed my rears but before i got them changed (about 2 weeks ago) they were all the same. they put on sceptors which ive never heard of so im sure theyre trash😭
Old 10-22-2021, 09:44 PM   #9
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
yeah i’m thinking something is loose which is what’s throwing me off. i’ll look for a reputable shop, thanks!
Old 10-22-2021, 09:45 PM   #10
julzbrz
julzbrz's Avatar
Drives: ‘14 brz
Sceptor 4xs? I aint never heard of those so I’m sure they threw on literally any tires and they kinda suck 😫 but it’s almost winter so i was just gonna ride them out until it starts to snow and then get winter tires. Any winter tire recommendations?
Old 10-22-2021, 09:52 PM   #11
soundman98
soundman98's Avatar
tirerack.com look through the reviews.
my first car accident was caused by a cheap, no-name garbage tire like that. it slipped, and slid everywhere. if the ground was even damp, ABS would kick in for many seconds, extending my anticipated braking distances by a matter of 30-50ft...
Old 10-23-2021, 12:03 AM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
So they only replaced the rear tires? Yeah that's why, and they sound like Garbage tires.
As mentioned start with alignment. If your toe is off it will cause all sorts of weird handling issues.
For deep snow driving Nokian hakkapeliitta R3, Pirelli ice zero FR, continental Vikkingcontact7's.
If you want better dry handling Pirelli sottozeros, or Michelin pilot Alpin PA4 are my picks.
Old 10-23-2021, 03:43 AM   #13
saltywetman
Drives: 2020 Toyota 86 GT 6M
The new michelin x-ice snows that came out last year and finally replaced the xice3's are pretty good too!
saltywetman is offline   Reply With Quote
Old 10-23-2021, 11:43 AM   #14
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
one would assume the OP has checked the tire pressure.
tires are life and death. choose wisely. most crashes around here involve a wet road so rain/wet tires are prudent.
thomasmryan is offline   Reply With Quote
Shuddering from rear when losing traction nickmerronesucks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-30-2022 05:32 PM
CEL + Losing Traction Light on after E85??? (Picture included) MatthewFRS Issues | Warranty | Recalls / TSB 22 11-29-2016 08:23 PM
Car losing traction in corners Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 03-06-2016 07:50 PM
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
