Old 10-12-2021, 07:20 PM   #1
mayoboost
Drives: boosted white FRS
Unhappy Broken hood latch cable :(
Welp, went to open the hood and the interior hood release lever was loose and wouldn't open. Pulled apart the lever mechanism and tried pulling the cable with some pliers but it sounded like I was ripping the cable off the clips under the hood or something.
I jacked the car up to reach from under, but the greddy turbo setup is making it extremely difficult to reach it. I'm not sure I can really even do anything from below at this point.
I also have no idea how to release the mechanism even if I could reach it.
Anyone have any ideas or recommendations on how I can get the hood open?
I attached a couple of images of the hood latch mechanism I found on ebay here: https://imgur.com/a/EbUW56r
mayoboost is offline   Reply With Quote
Old 10-12-2021, 07:24 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
maybe try asking a locksmith? they might have a tool that could reach in and unlatch it without damage
Old 10-14-2021, 08:44 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Maybe something like this guy is doing?
https://www.google.com/search?q=how+..._K0w_Pv72QDg30
Old 10-14-2021, 09:03 PM   #4
mayoboost
Thanks! Now I know what to push to unlock the mechanism!
Next part is seeing if i can even reach it somehow.
Old 10-19-2021, 01:32 AM   #5
humfrz
Bubba suggests you take a length of #9 wire, bend a hook on the end of it - then go fishing -
Old 10-20-2021, 04:23 PM   #6
mayoboost
Hmm, from the outside from under the front of the hood? It doesn't seem like I'd be able to get any lateral pull if I managed to get the wire hooked onto the latch.
From under, I can barely touch the latch housing due to the intake, turbo, and manifold in the way. Navigating a wire there is damn near impossible. I went in with an endoscope to give a look see, but it's not looking very feasible.
Any opinions on sawing off the hood hook with a hacksaw blade and then welding the hook back on? I can slip it under the hood and cut... Not sure if the welding part is viable, however.
Old 10-20-2021, 09:59 PM   #7
humfrz
I'm not understanding that if you can get a hacksaw blade against the hook of the latch, why you can't push it over (unlatching it)? -
OK, plan B. Have someone push down on the hood just above the latch while you pull on the wire that was attached to the latch handle? -
Old 10-20-2021, 10:18 PM   #8
pope
has a funny hat
Drives: 2014 BRZ Limited
Plan C: pull the fender liners and go in from the sides.
pope is offline   Reply With Quote
Old 10-20-2021, 10:19 PM   #9
soundman98
soundman98's Avatar
plan c. locate the hood release cable anywhere in the front end and yank it like nothing matters anymore.
Old 10-21-2021, 09:16 AM   #10
blsfrs
blsfrs's Avatar
Where is the cable broken? It might have come loose from the lever in the cabin. If so. you might get to it from in the cabin.
Old 10-21-2021, 10:26 AM   #11
Joon525
Joon525's Avatar
Drives: 2016 BRZ
This happened to a car at the shop last year.
If I remember the tech went in from under the car, he just removed the lower underpanel and reached up to unlock it manually.
Joon525 is offline   Reply With Quote
Old 10-21-2021, 04:44 PM   #12
mayoboost
I can push the lever that unlatches from the outside, but the first release mechanism that you pull from the interior is still latched. The hook I'm talking about sawing is the one attached to the hood.
It looks to have come undone from the hood latch mechanism. Pulling won't help in this situation
Have gotten this far, but the Greddy turbo set up blocks any kind of practical access to the mechanism.
Anyone know if the hood hook is replaceable? I attached a pic and looking at this picture, it seems there are two bolts that might belong to it, but I don't see a way to actually remove it if that were the case. If I can replace the hook, I'll just saw it off.
Will try the fender liners in the meanwhile.
Thanks for the help everyone!
Old 10-21-2021, 06:50 PM   #13
mayoboost
Welp, tried the fender liners but the chassis and crash bar are making it a no go.
My forearm is looking like ground beef after going in with a wire hanger from the bottom for almost 2 hours.
This is not looking good. The hacksaw blade is looking like the only option right now
Old 10-22-2021, 01:26 AM   #14
humfrz
OR ............
SOLD: Seibon VS-Style Carbon Fiber Hood w/ Quik Latch Hood Pins sixthspeed Exterior Parts (Aero, Lighting, Etc.) 16 02-07-2021 08:49 PM
Trunk latch broken B 86 Issues | Warranty | Recalls / TSB 12 01-18-2021 02:28 PM
WTB Hood pin/latch msaikhan Want-To-Buy Requests 0 07-19-2020 11:50 AM
Hood Latch Dilemma Mr Nerd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-04-2017 05:06 PM
WTB: HOOD LATCH AND DRIVER SEAT BELT ASSEMBLY 555 Want-To-Buy Requests 5 08-24-2015 04:57 PM
