Old 10-05-2021, 01:23 PM   #1
86prime
Drives: 18 BRZ tS
tS draw stiffener torque spec
Anyone know the torque spec for the tS draw stiffener mounting points?
86prime is offline   Reply With Quote
Old 10-05-2021, 04:21 PM   #2
p1l0t
p1l0t's Avatar
32-44ft/lbs? GUESS
https://www.ft86club.com/forums/showthread.php?t=134087
Old 04-27-2024, 06:38 PM   #3
86prime
Drives: 18 BRZ tS
bump, anyone have this info yet?
Old 04-27-2024, 08:10 PM   #4
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
2.5 years from your OP and you still couldn't figure it out? A simple Google search can help. Below is the pdf file that should be the same torque spec on the WRX installation, as you need to find the mounting points to torque down the bolts/nuts.
https://techinfo.subaru.com/stis/doc...%20F%20WRX.pdf
ZC6_STi is offline   Reply With Quote
Old 04-28-2024, 01:48 PM   #5
86prime
Drives: 18 BRZ tS
Hey if you're going to be condescending, at least provide correct information?
The 2018 tS service manual is available now from Subaru, and it has this info along with pretty much everything else:
https://www.ft86club.com/forums/show...=138337&page=2
Old 04-28-2024, 07:35 PM   #6
ZC6_STi
ZC6_STi's Avatar
I don't need to be condescending for bumping a 2.5-year post you've opened and you still couldn't figure out the torque spec. You could have just gone with the previous member's advice who posted a link to torque down the specs between 35-44/lbs. Why try to go through the process again, if a member already has the same part as you?
Again, the STi Flexible Draw Stiffener is an "accessory add-on" installation, not a service part. Several WRX parts fit on the BRZ platform with the same torque specs. Use your judgment on the torque specs and installing parts.
Old 04-28-2024, 08:14 PM   #7
86prime
Drives: 18 BRZ tS
If you don't have the correct torque spec (it's not 35-44 ft-lb), just say I don't know or at least gutentight? I'm sure the community would appreciate having the correct information out there. Google afaik didn't have this info, I'm not sure how I was supposed to figure out the spec. Well, I finally checked back with Subaru, which I should've done before bumping.
Anyway, here's the info from the service manual:
STI draw stiffener slifer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-29-2021 01:14 PM
TRD Flexible Draw Stiffener Gameboy9504 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-29-2019 01:33 AM
STI flexible draw stiffener nikitopo Brakes, Suspension, Chassis 4 04-14-2019 04:30 PM
Draw stiffener with Ace header clearence ayau Engine, Exhaust, Transmission 2 06-27-2018 09:36 PM
Subaru STi - flexible draw stiffener illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-29-2013 12:04 PM
