Old 10-04-2021, 02:09 PM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
best clutch for daily driver on JDL Turbo Kit
Hi All,
So I just ordered the JDL turbo kit and was wondering what ya'll would recommend for a clutch and flywheel and TOB once boosted for a daily driver. I don't plan on pushing anything more than 300 to the wheels and similarly not looking to push over 300 on torque numbers.
Neal at the Racers Line recommended the ACT clutch kit, wondering if anyone has any other suggestions especially since I'll be daily driving it. I'm in the South Bay in CA, I take my car up to SF if that makes anything different but hah not afraid of those big hills. Looking forward to what people have to say.
Best,
Aakash
DoubleAKash is offline   Reply With Quote
Old 10-05-2021, 05:56 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Avoid ACT like the plague.
Too many stories of problems to be a coincidence IMO.
South Bend stage 2 or something similar. Go by actual TQ ratting NOT "Stage" numbers.
OEM revised TOB
Leave the flywheel alone unless it needs to be replaced, then just get OEM or similar.
I'd swap out the clutch for while in there with an upgraded one.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
DarkPira7e (10-05-2021), kevaughan (10-17-2021), Sapphireho (10-05-2021)
Old 10-05-2021, 09:47 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I had the Exedy Stage 1(unknown rating), which held about 330whp and 250wtq, never slipped. I now have South bend stage 3 daily(rated to 400ft lbs) and it drives identically- if you want to future proof yourself, get southbend. If you trust you won't be going deep into the 200s with wtq, Exedy Stage 1 would be ideal
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (10-20-2021), kevaughan (10-17-2021)
Old 10-05-2021, 07:36 PM   #4
DoubleAKash
Thanks ya'll for the recommendations from more people that I've asked many of them recommend the Southbend clutches
Old 10-05-2021, 07:39 PM   #5
OEM revised TOB
Most ACT stories I've seen ultimately have come down to install. Lazy techs that just gun everything on, combined with a (pretty poor) plastic install tool.
Install the ACT with an OS Giken tool or similar, and torque slowly in a star pattern, and you won't have any issues.
Also, don't be lazy and just shove the transmission on. This can warp the clutch disc.
Old 10-05-2021, 07:57 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Very not true in my case. Mine was installed by a Subaru performance shop that has done hundreds of ACT clutches, dropped the trans two times after to re-check everything. They have decades of experience. They even have a long standing personal relationship with ACT. They don't use ANY gun in clutch install.
Believe it or not Mike, sometimes you are wrong.
Old 10-05-2021, 10:58 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
alphasaur (10-20-2021), humfrz (10-17-2021), kevaughan (10-17-2021)
Old 10-17-2021, 05:09 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Probably best to have a clutch that slips before the torque level that shreds the transmission; ie, don’t have the transmission be the weakest link. For the street, my Exedy stage 1 is pretty close to stock and has held a bar of boost.
Old 10-19-2021, 11:52 PM   #9
jflogerzi
jflogerzi's Avatar
Southbend clutches
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-20-2021, 12:04 AM   #10
alphasaur
friendly
Drives: 17' 86
Interested in how many miles on the exedy?
I'm about to install my turbo kit over the course of the winter and I am nearing 60k miles so I think a clutch install is in my immediate future.
Also wondering why people use the southbend stage 2 if the stage 1 is rated for 295lb ft?
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 10-20-2021, 12:41 AM   #11
jflogerzi
jflogerzi's Avatar
Those rated at the fly wheel and not at the wheels
Old 10-20-2021, 12:44 AM   #12
alphasaur
friendly
Drives: 17' 86
yes, but even at the wheels you're likely talking about it holding 250-260lb ft which is farther than most push with a turbo kit/supercharger kit with 220-230lb/ft seeming to be the sweet spot for engine longevity.
Old 10-20-2021, 08:41 AM   #13
DarkPira7e
DarkPira7e's Avatar
I had maybe 2k miles on it before my engine gave out. Not long on it, admittedly. I now have the southbend stage 3 daily because I wanted the overhead
The Following User Says Thank You to DarkPira7e For This Useful Post:
New clutch for a daily driver Griffin_Hay Engine, Exhaust, Transmission 8 04-06-2020 12:01 AM
Need clutch suggestions for daily driving a Turbo FRS CamFrs Engine, Exhaust, Transmission 8 04-04-2017 07:27 PM
Raven's WORKS Turbo Charged Daily Driver raven1231 Member's Car Journals 157 11-19-2015 07:46 AM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 10:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 02:14 PM
