Old 10-02-2021, 12:59 AM   #1
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
FS: Custom Turbo Kit w/ tons of extras
Located in San Diego. Possible to ship but I would prefer not to. Shipping cost would likely be pretty high since it would be heavy and a large package.
Custom Turbo Kit - SOLD
I am an automotive engineer and built this setup about 4 years and 15k miles ago. I still believe this is one the best setups for a FA20.
Included:
Borg Warner EFR 6758 - 0.80 A/R T4 Twin Scroll
Turbosmart IWG75 twin port wastegate actuator - 12 psi springs. Can run 12-20+ psi on this spring setup.
4-port boost solenoid
Turbosmart Race Port BOV
ACE 4-2-1 header with custom overpipe and custom investment cast 304 SS turbo inlet for the T4 twin scroll. Also comes with A350 overpipe to run NA if needed.
Custom intercooler with treadstone C1035 core which is rated for 600+ hp.
Modified bumper beam for intercooler mounting.
Mechanical cam-driven oil pump (from the FA20-DIT) and sump for the low mounted turbo.
Custom catch to integrate the sump vent.
Perrin engine mount brackets with brand new rubber isolators. Required for the close clearance of the twin scroll overpipe.
P-Tuning front sway bar (needed to clear low mounted turbo).
Perrin silicone radiator hoses with CSF aluminum water neck.
Perrin master cylinder brace.
Aluminum steering rack bushings.
ACT XT Street clutch kit (SB7-XTSS)
JDM ac delete pulley. Not necessary to fit the turbo though.
Nameless performance alternator and ac belt covers - Black.
All hot side components are coated with swaintech white lightning ceramic. This coating is very good but extremely hard to keep clean as you can see from the pics. Can be painted over with any high temp paint if you choose to do so. All cold side piping was just powder coated with a fine texture satin black when the kit was removed.
See the build thread for more info and pics of the turbo setup: https://www.ft86club.com/forums/showthread.php?t=99861
kask2_6.0 is offline
Old 10-04-2021, 12:54 AM   #2
Jo0
Drives: '17 CWP Limited w/ PP
Pretty nuts dude. I wish I had the cash for this right now. GLWS
Jo0 is offline
The Following User Says Thank You to Jo0 For This Useful Post:
kask2_6.0 (10-04-2021)
Old 10-08-2021, 01:21 PM   #3
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Price drop to $3800
Old 10-09-2021, 12:14 PM   #4
Gloonge
Drives: 2013 frs raven
I noticed there is an air filter located where your battery should be. Is it fair to say that this kit requires a battery relocation (to the trunk I am assuming)?
Gloonge is offline
Old 10-10-2021, 11:53 PM   #5
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Yes, it does require battery relocation.
Old 11-05-2021, 12:48 PM   #6
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Bump. $3200. Moving soon and I don’t want to move these boxes. Someone come get it! It’s a whole lot of parts for that price.
Old 11-24-2021, 12:26 AM   #7
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
SOLD!
CUSTOM GREDDY TURBO KIT GT3076R, FLEX FUEL, EXTRAS, COMPLETE boostedbrz Engine, Exhaust, Bolt-Ons 16 09-24-2018 06:18 PM
FS: Like new JDL UEL Turbo Kit w/extras blueap2 Engine, Exhaust, Bolt-Ons 1 02-22-2016 11:20 PM
SBD Turbo kit w/extras The Racers Line Engine, Exhaust, Bolt-Ons 14 04-10-2015 08:57 PM
SOLD: Wilwood Front Brake Kit (BBK) with tons of extras! (NoVA) swift996 Brakes, Suspension, Chassis 27 05-13-2014 09:37 AM
