Northwest AK, ID, OR, WA
Old 09-28-2021, 02:23 PM   #1
bokehmon
Drives: 2014 DMG BRZ
Maf for testing
Hey NW crew - I've installed my edelbrock supercharger, but have been having some weird fuel trim issues (+/-30), and believe that it may be a sensor issue.
I've smoke tested the intake for leaks, but haven't found any. I've also replaced the o2 sensor with no discernible difference, which leads me to believe that the maf or wiring may be faulty (can't see/feel any leaks in the exhaust either)
I've got a 2014 brz - not sure if there's a difference between years and mafs though.
Does anyone in the larger Seattle area (I'm in Lynnwood) have a maf that I could borrow for testing?
bokehmon is offline   Reply With Quote
Old 09-28-2021, 06:16 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’m too far to help though I have a suggestion. I would log the car at a steady state. Look at what the maf voltage is reading. If the car is idling for a minute and the maf voltages are all over the place it’s probably the maf.
Old 09-28-2021, 11:05 PM   #3
bokehmon
Thanks! They're between 1.0 and 1.7~, which looks OK. g/s are also within spec.
I'm actually seeing the issues around 2700 rpm at steady state (stft goes to +30, and ltft goes to +40 max). It's definitely concerning.
I'm going to go back to stock header and try to eliminate things one by one. I'm wondering if i just have a dirty injector or something.
Old 09-29-2021, 12:38 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What are you using for a base tune? Does it gradually build stft/ltft or does it spike?
Old 09-30-2021, 03:55 PM   #5
bokehmon
I actually had it tuned @ Drift Office, but they've also created the same tune for other cars and have no issues - sounds like I have something weird going on with my car.
Here's a 60~MPH cruise - you can def see the LTFT and the STFT spiking
https://datazap.me/u/bokehmon/log-16...&data=31-34-35
Old 09-30-2021, 04:12 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The AFR is bouncing around target so it is trying to compensate, I would guess that likely O2 is reading correctly if that is the case. Beyond what I can help with
Old 10-01-2021, 01:18 PM   #7
bokehmon
No worries - really appreciate the help!
I think I'm going to slowly remove variables, hopefully I won't have to re-install the supercharger.
Old 10-05-2021, 11:35 AM   #8
JoeS
Drives: 2016 BRZ Hyper.Blue
Did you get this sorted out? I have MAF sensor that you can borrow, but you'll need to either pick it up today or wait until the 10/15. I'm in Renton.
JoeS is offline   Reply With Quote
Old 10-05-2021, 12:15 PM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Ode to Renton
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 10-05-2021, 08:38 PM   #10
bokehmon
Just saw this - probably too late to come pick up, unless you're there late!
I didn't - i just checked the header for leaks - looks fine, so probably some thing top side (maf, vacuum leak[?])
Messaging you my # if you're in Renton still - I can drive down today.
Update: got an appointment with the Drift Office guys - they're taking a look at it on Saturday. Thanks everyone!
Old 10-12-2024, 09:44 AM   #11
02maher
02maher's Avatar
Drives: Gt86 2013
Hi did you fix the issue? I have similar LTFT and when I’m in neutral flooring the pedal there’s a lag especially at around 2k rpms… I noticed there’s no lag when I remove the maf sensor and accelerate in neutral… my maf sensor voltage fluctuates between 1.15 and 3.90.
02maher is offline   Reply With Quote
Testing of me new car :) FishMac FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 04-20-2013 05:38 PM
just testing sig mrlewistan Off-Topic Lounge [WARNING: NO POLITICS] 1 02-25-2013 04:13 PM
testing FT-MH Announcements, Contests, Giveaways 14 07-31-2012 11:00 PM
