Old 09-19-2021, 02:31 PM   #1
brzlegend
Drives: brz
dual pump control
You can run the second fuel pump by buying another oem fuel pump controller and piggy backing off the two small control wires from the ecu. Use a relay and fuse for the power on the second one, each controller will run a 285 walbro (hellcat pump) simultaneously, it does not ovewhelm my regulator.
brzlegend is offline   Reply With Quote
Old 09-20-2021, 01:04 PM   #2
ML
ML's Avatar
Drives: 13 White MT FR-S
jUsT gEt A sUrGe TaNk
Old 09-21-2021, 09:36 PM   #3
brzlegend
Drives: brz
Still have to power the pumps in a surge tank. Three oem fuel pump controllers could run a dual pump surge tank setup. Oem electronics are always more reliable than aftermarket and PWM controllers puts less heat in the fuel and pump. I bought an oem fpc from ebay for $20.00.
The Following User Says Thank You to brzlegend For This Useful Post:
NoHaveMSG (09-22-2021)
Old 09-22-2021, 11:56 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks for that tip. Just picked up an FPC as well off ebay for cheap.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
brzlegend (11-18-2021)
Duel Purpose uild recommendations BRZoombra Tracking / Autocross / HPDE / Drifting 15 04-09-2018 01:05 PM
FS: duel 10" bandpass sub box scottman Canada Classifieds 6 10-28-2017 05:00 PM
Duel In The Desert 3/9/13 Chandler, AZ The Kirby Southwest 2 03-08-2013 06:54 PM
Duel In The Desert 3/9/13 Chandler, AZ The Kirby Southern California 2 03-05-2013 11:41 AM
Duel Exhaust tips? ScionFrsFan Cosmetic Modification (Interior/Exterior/Lighting) 4 02-12-2013 08:39 PM
