Old 09-07-2021, 03:27 PM   #1
Futaba
Futaba's Avatar
Drives: GT86
Headlight washer electronics
Does anyone happen to have a UK/Euro/etc electrical wiring manual for a GT86 that has headlight washers?
I'm attempting to install an OEM headlight washer system but from what I could see the vehicle is missing the connector for the harness for the second, 30A pump.
Also does anyone know the model/code for a connector that would fit this? (OEM 30A headlight washer pump)
As I understand it, the vehicle should provide power to H-LP fuse in the fusebox when headlights are on and windshield washer is in use, if that's the case, if the vehicle is indeed missing this connector on the loom I should be able to restore it by adding the connector and cable to the fusebox.
The UK spec washer bottle has a relay marked "Relay Cleaner Cont." bolted to it which I'm going to guess is a timer relay that activates the secondary pump after a set time.
Again, the JDM loom doesn't seem to have a connector for this relay.
Anyone else done this?
It's it even worth patching in? I mean I could just run a wire from H-LP Washer 30A in fusebox via a dashboard switch to the pump, but I was hoping for a more OEM approach.. I guess I could swap the entire loom for a UK spec one but that feels excessive!
Futaba is offline   Reply With Quote
Old 09-08-2021, 07:56 AM   #2
Futaba
Futaba's Avatar
Drives: GT86
So digging around I managed to find a wiring diagram for BRZ that includes the headlight washer system, as above it seems the koito relay that's bolted to the washer bottle needs feeding lines from IG1, Washer, HRLY, BR-W from wiper switch, and ground, then the remaining pin goes to the secondary pump, the other side of which connects to the 30A H-LP Washer in fusebox.
I would assume since the relay just expects to see various power inputs from headlight, washer and ignition that the timer part of the relay will operate the secondary motor based on headlights being on and windscreen washer switch being operated, all independently of the ECU.
Ordered a bunch of parts, will document the process of adding headlight washers to a non-hl-washer vehicle once they arrive.
The Following User Says Thank You to Futaba For This Useful Post:
LimitedSlip (09-08-2021)
Old 09-08-2021, 04:50 PM   #3
Futaba
Futaba's Avatar
Drives: GT86
The model number for the BRZ relay is 88018SC010, but the only pinout I can find for these Koito relays is for a Subaru 88018FE010, the pinout of which is what I included in the above image.
88018FE010 PCB markings:
3 : HL
2 : MOTOR
1 : IG
6 : WASHER
5 : GND
4 : ACC
But the BRZ wiring diagram seems to show the pins for the relay as being :
3 : HRLY
2 : HL Washer Pump Negative
1 : IG
6 : Wiper switch control
5 : GND
4 : WASHER (WS Washer Pump Positive)
Looking around, I saw the following stated for a 88018FE010 for a Subaru Forester:
HL : Headlight negative
Motor : Negative of HL Washer pump
IG : Ignition (+12V power)
Washer : Windscreen washer pump negative
GND : Chassis ground
ACC : Windscreen washer pump positive
Getting mixed messages with the wiring diagram versus the PCB markings for the 88018FE010, but can't find pinout or pcb image for a 88018SC010
Any ideas folks?
Old 08-04-2025, 10:08 AM   #4
SiCaln
Drives: Mini, Own TRD 14R
This may be late to the party, but I did get this to work, with the aid of some of these posts and an auto electrician! We have got it to work from the stalk and only works when the headlights are on and not every time the washer is pulled (relay driven).
Here is the way we wired it
and it working
If you want to follow along, it is also here
Maybe 1/1 in the UK TRD 14R owner, check out my youtube channel below
https://www.youtube.com/@GarageeightSix
SiCaln is offline   Reply With Quote
The Following User Says Thank You to SiCaln For This Useful Post:
Luns (08-04-2025)
Old 08-04-2025, 03:43 PM   #5
gpvecchi
gpvecchi's Avatar
I just replaced the bumper on my EU to remove the headlights washers
gpvecchi is offline   Reply With Quote
Old 08-06-2025, 05:56 AM   #6
SiCaln
Hehe, I don't have an option, it is part of the UK MOT for cars with Xenons
gpvecchi (08-06-2025)
UK Spec Headlight Washer Install - Questions! Futaba Cosmetic Modification (Interior/Exterior/Lighting) 3 08-04-2025 10:18 AM
Headlight washer assembly Deemsim Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-11-2021 11:35 PM
Electronics are freaking out.. HillCountryGuru Issues | Warranty | Recalls / TSB 5 05-15-2014 01:50 AM
JDM Headlight Washer ”Sticker“ on Front Bumper Figo Cosmetic Modification (Interior/Exterior/Lighting) 31 04-04-2014 07:01 PM
LS swap electronics mhiscott Engine, Exhaust, Transmission 8 12-20-2013 07:52 PM
