Old 09-05-2021, 04:07 PM   #1
TrashFRieS
Drives: 2013 Scion FRS
Help please? (Car died driving home, $400 later and it just barely starts up)
Replaced MAF and some fluids. But this thing won’t make it down the street in this condition. Any and all advice is appy
TrashFRieS is offline   Reply With Quote
The Following User Says Thank You to TrashFRieS For This Useful Post:
humfrz (09-06-2021)
Old 09-05-2021, 04:07 PM   #2
TrashFRieS
Appreciated**
Old 09-05-2021, 05:55 PM   #3
obscene_gesture
Drives: 2025 GR86 Premium MT
Just spit-balling here, but do you know if it had the valve spring recall done?
obscene_gesture is offline   Reply With Quote
Old 09-05-2021, 06:02 PM   #4
TrashFRieS
I don’t know for sure. Is there a place I could check that?
Old 09-05-2021, 06:17 PM   #5
obscene_gesture
Carfax?
By the way, do all the belts look ok?
Old 09-05-2021, 06:41 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
motor is toast. guessing the guy had the recall done then unloaded it on you. 7k ish to fix.
I feel really bad for you. Your 86 experience should have been a good one. I've been there on this
Old 09-05-2021, 06:43 PM   #7
obscene_gesture
Also, I don't know if this is relevant, but your coolant reservoir looks like it's really over-filled and isn't using the normal blue coolant.
Old 09-05-2021, 07:35 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yup. Goner. Hopefully, you can make a decent score on a salvaged long block. Really sorry about that.
Old 09-05-2021, 07:36 PM   #9
TrashFRieS
Carfax?
Belts are all solid. Mechanic came out and said I’ll probably end up needing to replace the entire short block
Old 09-05-2021, 07:49 PM   #10
TommyW
TommyW's Avatar
Get a new one. The shop will also redo the heads and valves. Don't get anything used.
The Following User Says Thank You to TommyW For This Useful Post:
soundman98 (09-05-2021)
Old 09-06-2021, 02:03 AM   #11
humfrz
Well, that's too bad -
What puzzles me is that you said the car was running fine then you did some routine maintenance, now it hardly runs. You may try putting the old MAF back in the car to see if it makes a difference -
That engine sounds like an old flathead V-8 that has a distributor half full of water -
OK, so you don't have a distributor. -
You mentioned that you have had to charge the battery several times. What kind of voltage to you get at the battery without the car running? The battery sounded weak.
What trouble codes are being thrown at you? If you don't know, I suggest you invest in a code reader.
Since the engine hasn't "blown up", I reckon there is a massive fuel delivery or massive spark malfunction.
Let us know what you find out.
Old 09-06-2021, 02:37 AM   #12
TrashFRieS
Waiting for the holiday weekend to be over so I can hear back from the lot I bought it from on if/when the recall work got done.
Old 09-06-2021, 02:43 AM   #13
TrashFRieS
The routine maintenance happened as a result of the failure. The guy that sold me the thing assured me up down left and right (but not in writing) that the car had been meticulously cared for. Only invested in the new MAF after getting P0102. And as far as the battery goes after the failure it was seen to be bleeding. Not sure if this was a cause or result of the failure. Thank you for your comments, will keep you updated
humfrz (09-06-2021)
Old 09-06-2021, 02:48 AM   #14
TrashFRieS
**update** I’ve resigned myself to getting a salvaged short block after a second mechanic has told me that the problem is a thrown rod. so as I scour pull-a-part and other salvage yards, I ask for your advice on getting through this step as quickly as possible. This thing is my daily driver and getting it road worthy again ASAP is my top priority.
Ayo what da dog doin’ Flunoir Scion FR-S / Toyota 86 GT86 General Forum 81 07-02-2022 10:40 PM
Any concerns driving brand new 86 400 freeway miles home? TooSlow Scion FR-S / Toyota 86 GT86 General Forum 28 06-03-2018 02:58 AM
I died when I saw this.. Koa Scion FR-S / Toyota 86 GT86 General Forum 71 03-30-2015 10:48 PM
Pulled over on way home from dealership in our project BRZ...Wreckless Driving! JRitt BRZ First-Gen (2012+) — General Topics 33 05-30-2012 07:22 PM
