Drives: 2013 Scion FRS
Hunting down my P0172
So I've been getting a rich code in my 2013 FRS, It's accompanied by a raspy start up that feels like it wants to stall but never actually does (it always evens out a few seconds after starting), a hesitation around 4000rpm that becomes more noticeable at WOT, and a pretty consistent misfire around 2.5-3000rpm.
I've cleaned the MAF, checked the intake and oxygen sensor, Replaced the spark plugs and had all 8 injectors cleaned and tested. Mods include an intake, ft86factory header, nameless helmholtz resonator, and an invidia n1 catback exhaust I've been chasing this issue on my own for over a month now so any input helps, thanks in advance Last edited by LightningCount86; 08-25-2021 at 02:48 PM. |
#2 | |
LMGTFY
Drives: 13 FRS, 91 Miata
If your not tuned I'd get that done first. |
#4 | |
Drives: Crapcan
And the part you have is a nameless front pipe. The helmholtz resonator is just an add on to the part. This means you also have a high flow cat in the front pipe too.
Yes that's correct, If it was simply a tuning issue though that'd probably make my job alot easier which is why I initially bet against it being the problem.
LMGTFY
Drives: Crapcan
Probably not, but it is not helping. I'd be curious what a log looks like. Could be coil pack but I would think it would be misfiring more.
#9 | |
Drives: Crapcan
I would say likely a coil pack. Would be nice if you had a way to log so we could see which cylinder was misfiring, then rotate the packs and see if it follows to the other cylinder.
#10 | |
I also heard someone say it could possibly be the camshaft position sensor but imma check this first and see what happens |
#11 | |
Drives: SWP BRZ
enjoy replacing coilpacks which i dont want to do with this boxer engine i would replace spark plugs when you do this as well |
#12 |
Update: So I changed out the coilpacks, car feels noticeably faster at lower rpm but still has the hiccup and hesitation at 2000 and 4000 rpm
#13 |
Drives: 2015 FR-S
You mentioned you have an aftermarket intake. That would require MAF REscaling especially if it’s CAI
#14 |
Update: So I found a stock intake, new MAF, new filter, still running rich. Problem is actually getting worse tho, as the car recently starting stalling out when coming to stop coming to stops and also occasionally while moving. Once again any help goes a long way,
| Tags |
| check engine, misfire, p0172, rich |
| Advice on Used BRZ Hunting | jello_fello | BRZ First-Gen (2012+) — General Topics | 24 | 03-06-2021 03:55 PM |
| Idle Hunting/Surging | Newtothegrounds | Issues | Warranty | Recalls / TSB | 3 | 01-23-2018 01:27 AM |
| Idle Hunting/Surging | Newtothegrounds | Issues | Warranty | Recalls / TSB | 4 | 01-22-2018 10:36 PM |
| brz - idle is hunting | kravi | Issues | Warranty | Recalls / TSB | 9 | 01-17-2016 09:37 PM |
| Idle hunting on park | WishIhad86 | Issues | Warranty | Recalls / TSB | 7 | 04-12-2015 01:19 PM |
