Old 08-24-2021, 04:59 PM   #1
gm5oh
Cruise Knock Issue
Hello all,
I am having an issue with knock at cruise but none any reoccurring at WOT. I've sent countless logs to my tuner and we have tried to pull timing at those areas but it seems that the cruise knock (knock corr. + flkc) continues to come back. I've ensured that there is nothing in my engine bay that could be causing this knock reading. I do want to mention that I do not recall this happening during Fall / Winter times last year. I do live in south Florida, so the heat could be the cause of the issue, but then again, the intake comp table should take care of this. Something important things to note is that this problem occurs on 93 + e85, I have never seen flkc or knock corr. be any less than -2, my car is tuned via OFT, and it does not always happen. I have had a hard time recreating this issue while the motor is cold during cruise.
If you could please take a look at the following logs and let me know how to troubleshoot this / let me know if this is something to even worry about I would greatly appreciate it!
Logs:
EDIT:
FP + OP is this close to sway bar. Not sure if it would have that much play, however.
gm5oh is offline   Reply With Quote
Old 08-25-2021, 07:19 AM   #2
steve99
very likely that knock may be due to mechanical rattle or vibration of exhaist on chassis or skid plate fooling knock sensor
Pull 5 degrees out of the entire base b timing map
if knock doesnt change then its very likely rattle vibration problem its a common issue
if the knock goes away with 5 degrees out of the map then likely fueling ignitin timing issue
gm5oh (08-27-2021)
Old 08-25-2021, 07:55 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
TBH if it's at cruise then it's not really an issue, not enough cylinder pressure. It's almost impossible to completely stop any form of knock correction triggering and you can ruin the feel of the car doing so. Let the ECU pull timing if it wants in lower load, that's what it's designed to do.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
gm5oh (08-27-2021), steve99 (08-27-2021)
Old 08-27-2021, 01:12 AM   #4
gm5oh
Thank you, I'll reply again soon when / if I find a solution.
Old 09-17-2021, 04:33 PM   #5
gm5oh
Hey Steve, I am pretty sure I've narrowed down my cruise knock to having UEL headers, no factory heat shields, and being down in South Florida where it is really hot 75% of the year. I do not have header wrap because I don't want my headers to crack and in the event I have an oil leak, I do not want my car up in flames.
Note: Before I got an oil cooler, after doing some light pulls I would get to oil temps of upwards 240+ degrees Fahrenheit. It wouldn't take me any more than 3 minutes driving to get to 185 degrees Fahrenheit.
Tagging @Kodename47 so he sees this too. What do you guys recommend? I was thinking of wrapping my OP + FP in header wrap, but I am hesitant that my OP / FP could crack.
Please let me know what you think
Old 09-18-2021, 04:26 PM   #6
steve99
its unlikely its due to heat from headers many people run caltess header no shield, it more likely due exhaust hitting on chassis or shid plate
Cannot solve transient knock issue high RPM when letting of throttle (boosted) brosifSmith Software Tuning 6 07-10-2020 11:07 AM
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 04:57 PM
FML: Tired of the same old coil pack issue? Enjoy your new rod knock... Yigal.K Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-31-2018 04:25 PM
Issue: Cruise Control no bump up or down bcj Issues | Warranty | Recalls / TSB 4 06-13-2016 05:40 PM
CEL and Cruise Issue??? mortybryant Scion FR-S / Toyota 86 GT86 General Forum 7 03-23-2015 01:49 PM
