Old 08-24-2021, 02:51 PM   #1
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Educational video: Will the brakes from a different car/trim level fit my car?
We get this question or see it posted here on the automotive forums just about every day. It often stems from a desire to add disc thermal mass, or just an aesthetic upgrade, without investing in a complete brake kit (which is fine if done properly!). Unfortunately, the process of swapping the discs from one car to another isn't quite as simple as it seems, even when the new discs appear to be the 'same size' as the ones already on your car.
In our latest video we examine the critical disc dimensions that determine if the swap will work on your car vs. leaving you with some very expensive paper weights!
0:00 - Introduction
0:55 - Disc Diameter
1:17 - Disc Thickness
3:12 - Radial Depth
5:20 - Offset
6:42 - Mounting Pattern
8:25 - PCD
Be sure to check out the Essex Learning Center for more videos and articles on brake tech.
Thanks, and hopefully some of you find this information useful.
JRitt is offline   Reply With Quote
brake, brembo, disc, rotor, swap
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
WTB: oem shifter trim, steering wheel trim, and door handle trim frs_caskey Want-To-Buy Requests 3 03-28-2017 05:38 PM
How to remove rear seat cushion, quarter panel trim, and B pillar trim zombieite DIY (Do-It-Yourself) Guides 0 03-21-2015 11:32 PM
Which trim level would you choose and why? gt8613 BRZ First-Gen (2012+) — General Topics 25 09-15-2014 12:37 AM
