Old 08-24-2021, 02:19 AM   #1
gpvecchi
gpvecchi's Avatar
EPS ECU replacement
I read the procedure for replacing the EPS ECU, and it says to perform an assist map writing with Techstream.
What is it?
I'm asking because I'm replacing my EPS ECU with STi/tS one.
Thank you!
gpvecchi is offline   Reply With Quote
Old 11-16-2021, 02:09 PM   #2
RedReplicant
Drives: None
Does this unit provide less assist?
RedReplicant is offline   Reply With Quote
Old 11-16-2021, 03:52 PM   #3
gpvecchi
gpvecchi's Avatar
More assist to compensate bigger wheels.
The Following User Says Thank You to gpvecchi For This Useful Post:
RedReplicant (11-16-2021)
Old 02-12-2023, 02:43 PM   #4
amirnew
Drives: 2013 BRZ sprintex SC
What is it?
Thank you!
How did that work for you?
amirnew is offline   Reply With Quote
Old 02-13-2023, 12:58 AM   #5
gpvecchi
gpvecchi's Avatar
It seems that that procedure is standard on Techstream, and it is listed for 86 too, even if it doesn't work.
Best replacement TOB Muskoka800 Engine, Exhaust, Transmission 69 02-19-2021 06:12 PM
Hip replacement and the BRZ g e BRZ First-Gen (2012+) — General Topics 10 07-06-2018 06:12 AM
Replacement Key 86 South Africa AFRICA 7 09-19-2016 03:58 PM
Fluid replacement. RaveSaint5 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 10-25-2014 07:34 AM
Replacement fun? Mooseknuckle44 Scion FR-S / Toyota 86 GT86 General Forum 44 05-01-2014 11:46 AM
