Old 08-23-2021, 12:52 PM   #1
pro_turbo
Drives:
CAN BUS translator
Is there any guy here who can help me to decode the can bus data from oem ?
I need the shift up , shift down data from oe lingo to translate to use in my M1
Car is Auto
Also paddle shift + and - command data.
Thanks guys
pro_turbo is offline   Reply With Quote
Old 08-23-2021, 01:37 PM   #2
ayau
Drives: Some rust bucket
I'm assuming you have some software engineering skills but this project decodes the CAN data. They don't have a specific BRZ/86 file, I would assume it's similar to the existing Subarus.
https://github.com/commaai/opendbc
Old 08-24-2021, 10:40 AM   #3
pro_turbo
Drives:
Hey thanks so much..
I will dig into it
Old 08-26-2021, 02:14 AM   #4
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Car is Auto
Thanks guys
I didn't look at the data from automatic transmission specifically (my car is a manual), but you might be able to find some other interesting stuff I documented here:
https://github.com/timurrrr/RaceChro...can_db/ft86.md
If you find more info on various CAN IDs and data formats, feel free to send a pull request!
timurrrr is offline   Reply With Quote
The Following 4 Users Say Thank You to timurrrr For This Useful Post:
pro_turbo (08-27-2021), RedReplicant (10-07-2021), Takumidesh (10-01-2021), whataboutbob (08-26-2021)
Old 08-27-2021, 10:07 AM   #5
pro_turbo
Drives:
thanks again...im going to look into it
Old 10-01-2021, 02:44 PM   #6
Takumidesh
Takumidesh's Avatar
Drives: 2013 FR-S, 2015 TC
I am pretty interested in working with the can bus and working independently on some things with the car. I actually found your GH doc a few months back and it was immense in jumpstarting my progress so kudo's!
Can I ask what you are using to talk to the car? I am using a breadboard with mcp2551 and mcp 2515 + arduino mega2560.
I get communication and everything but my biggest struggle as it stands is communication speed, any tips?
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY
KANSAI DORIFTO
Takumidesh is offline   Reply With Quote
Old 10-01-2021, 09:39 PM   #7
markitect
Drives: Scion FRS
I'd recommend an ARM based controller, lot more power. I was recently looking at this combo, but haven't tried it out yet Should be convenient to either connect as serial, or store on the flash card.
markitect is offline   Reply With Quote
Old 10-02-2021, 10:54 AM   #8
Takumidesh
Takumidesh's Avatar
Yea I think the issue is with using the USB serial on the Arduino, I'm trying today to connect the connections directly to the spi io pins on my rpi 3.
KANSAI DORIFTO
Old 10-04-2021, 02:41 AM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Please check my GitHub again, it has a detailed description of the whole project and all the components
The Following User Says Thank You to timurrrr For This Useful Post:
Takumidesh (10-13-2021)
Old 10-13-2021, 12:56 PM   #10
Takumidesh
Takumidesh's Avatar
FYI anyone looking into working with can bus should read The Car Hacker's Handbook. it is focused on penetration but it goes in depth on automotive bus protocols.
KANSAI DORIFTO
LS3 swapped BRZ with EVERYTHING working - Plug in Canbus Translator toddy101 Engine Swaps 20 04-13-2020 12:39 PM
New Canbus Translator geraldjust Engine Swaps 18 04-23-2019 03:57 AM
