Drives: Whiteout track car; lava donor
Check your nuts!
In a quest to check every nut on my rear suspension, since I found a dangerously loose aftermarket toe rod nut, I found another loose one.
I replaced the left rear axle at the start of the season. Torqued it with an accurate torque wrench to Subaru/Toyota specs. Even dimpled it as instructed. Well, after countless track days, the axle nut had backed out about a quarter turn. Now it is torqued to "Les Schwab Monkey Lads with a semi truck impact gun"tm tight. Running R comps seems to put much more stress on everything and work nuts loose. So check your loose nuts, beyond the big one sitting behind the steering wheel. |
| The Following 3 Users Say Thank You to Four_wheel_drifts For This Useful Post: |
Drives: 2016 Scion FRS
Keep an eye on that. If they back off repeatedly, it is a sign of a bad hub.
| The Following User Says Thank You to steverife For This Useful Post: | Four_wheel_drifts (08-19-2021) |
Drives: Crapcan
I notice the lock nut on my RacerX Toe arms and LCA's like to come loose. If you have the LCA's or toe arms apart again, I would cross drill the lock nut and run some nylon tipped set screws in them. I went to SPC toe arms and they haven't come loose yet.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Four_wheel_drifts (08-19-2021) |
I marked the axle nut and axle end with a sharpie and checked the mark between runs. No movement over two days.
It would have been three days. Unfortunately, at the end of day two, my right front braided brake line (Goodrich) cut loose. Of course no store in Shelton had a metric 10-1 to 1/8” NPT brake line nor adapters for me to make a line. So I instructed only on Sunday. New, updated RR Racing lines and adapters showed up today. With these, I’ll be able to use the spare brake lines from Aaron if I loose another line in the future. I bought the RR Racing system in 2016; I should have planned for the weak link in the system failing at some point. Line looked like it was damaged initially by an impact (rock?), then eventually failed at the kink which I hadn’t noticed. I really appreciate that the Ridge added run off asphalt at turn 13. Not a place where you want the brake pedal to go to the floor, without a hill to slide up and scrub speed (ala turn 2). Last edited by Four_wheel_drifts; 08-26-2021 at 08:32 PM. Reason: Grammar |
#5 | |
Drives: 2013 BRZ Sport-Tech
#6 | |
Drives: Crapcan
This is the first time I’ve had one fail. It lasted about four years and many, many track hours.
The speed and g forces we put on these cars, breaks things, makes parts come loose, or plain wears them out. Especially since I started running r comps again! The lines were a good brand. Track demands just took their toll. |
Drives: Scion
We over torque those bolts with long wrenches and use a paint pen to mark our alignment position. The mark helps with returning the alignment quickly back to close to where it needs to be when it moves. But, yes, put wrenches on these bolts every session.
In SCCA T4 configuration, 2925lb min with 55mm restrictor plate times were 55's/56's at The Ridge. 54's in the AM right conditions are doable R |
| Check engine light then a traction control light then just a check engine... and then | Jstyle | Issues | Warranty | Recalls / TSB | 13 | 02-15-2021 05:10 PM |
| [SoCal] FS: Rays Dura Nuts Lug Nuts 12x1.25 | scotterson | Wheels and Tires | 8 | 12-17-2020 02:33 PM |
| FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve | neilvosko | Wheels and Tires | 14 | 06-18-2018 09:47 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| This car is nuts!!! 200 hp?!? No way. | Jen | Scion FR-S / Toyota 86 GT86 General Forum | 408 | 04-23-2014 03:00 AM |
