Old 08-18-2021, 08:56 PM   #1
1quickchic
Drives: 2013 Panda ft86/FRS
odd starting issue
Ok looking for an opinion on this, as I'm narrowing down the issue that is at cause
13 frs starts sometimes, then it doesn't, just cranks(engine spinning) nothing
auto car no clutch switch, when it doesn't start can unbolt the 2 grounds in the back on the block and reconnect them and it'll start run etc., then after it sits it repeats.
have added grounds to the di ecu, and to the block
have cleaned the grounds
and cleaned the battery
imob isn't triggering and no key symbol issues
mech fuel pump replace, in tank pump replaced
battery is new, and holding charge, while running it drives fine
it has acted a couple times like its cutting out (losing fuel)
but like said after the reset it if fine again
im leaning towards bad di ecu or main ecu
has no codes i can scan it it when it happens and has nada
1quickchic is offline   Reply With Quote
Old 08-18-2021, 09:10 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
When it doesn't start, and before you crank, are you listening for the fuel pump? It makes a distinct whirring noise when you first turn the key to the ON position until it builds up pressure and shuts off. Then, after you start the engine, the pump will begin to run again.
You say that you have already replaced the fuel pump, but did you also replace the fuel pump RELAY? It is not uncommon for relay contacts to start to fail intermittently.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 08-18-2021, 10:25 PM   #3
1quickchic
Fuel pump does run
Old 08-19-2021, 12:14 AM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Fuel pump does run
But......does it run EVERY time? And did you try replacing the fuel pump RELAY?
Old 08-19-2021, 03:12 PM   #5
1quickchic
yes it runs every time, I'm gonna try the relay today though the pump has always ran and I am showing pressure. also going swap the di computer as i am suspecting its the issue at this point
tech stream didn't give anything conclusive
Help with engine starting issue Locost7 Engine, Exhaust, Transmission 0 02-27-2021 04:14 PM
New motor - starting issue protpibe Engine Swaps 24 06-01-2015 01:01 AM
Starting issue? winsometang Issues | Warranty | Recalls / TSB 7 11-26-2014 06:25 PM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 08:40 AM
Van starting issue-need advice. LivingLegend Off-Topic Lounge [WARNING: NO POLITICS] 3 01-15-2013 11:48 PM
