Old 08-07-2021, 12:43 PM   #1
FRW-86
Drives: 2017 Toyota 86
2017 Toyota 86 Edelbrock S/C 9,740 Miles
2017 Toyota 86 Ablaze Red Excellent Condition 9,750 miles **SOLD****SOLD****SOLD****SOLD****SOLD****SOLD**
Fully Street Legal, NC Registration and Title
- **Edelbrock Supercharger** With spare optional 3.0" Pulley
100,000 mile sealed lubrication $4,850.00
- 6 Speed Paddle Shift Automatic Very Tight and Responsive
- 4.30:1 Torsen Differential, have spare 4.1:1 $385.00
- Wilwood Big Brake Kit 12.88" Ventilated Rotors 6 Piston Front/4 Piston Rear,
Spare set of Pads $3,450.00
- Console Adjustable Performance Options
- Jackson Aluminum Coolant radiator/Oil Cooler with thermostatic Oil Filter adapter
Cold A/C $450.00
- TRD 21MM Front bar, Stock rear bar $100.00 used
- ISC N1 31 way Adjustable Coilovers with 3S springs, Camber Plates, and Dust Covers $1,450.00
- Meagan Tie rod ends, Engine Mounts $125.00
- White Line Bushings and Stiffening Inserts Steering Rack, Diff mounts
(Have several packages of bushings for stock control arms not yet installed) $450.00
- Aluminum ISC Billet Adjustable Rear Lower Control Arms $350.00
- DOM Adjustable Trailing arms with Aircraft Fittings $125.00
- Adjustable Rear Toe Links with Aircraft Fittings $100.00
- DeRale Transmission Cooler with Thermostatic Fan Control and aircraft fittings plumbed into stock thermostatic cooler
via 1/2 inch HD hoses with thermal C/F sleeves - $240.00
- Enkei Rajiin 18x9 5x100 ET45 Wheels $1,200.00
- Federal SS595 High Performance Tires 235/45ZR18 Front 245/45ZR18 Rear 1,800 miles $385.00
- Delicious Tuning Stg1 $395.00 and Edelbrock 50 State Legal Tunes Came with S/C
- EcoTek Tuning OBDII Interface and Tuning Software Came with S/C
- 253 RWHP 216 FtLbs Torque (Have Dyno Sheets for both Stock and Current)
- Mishimoto Chill synthetic coolant throughout
- Fresh Royal Purple oil and K&N Filter change, Spare Oil Filters $65.00
- Fresh Royal Purple Diff Fluid $38.00
- Deutsch 300 fuel pump $160.00
- Versus Engineering Fuel Pump check valve to prevent fuel starvation under high G loads $70.00
- Invidia SS N1 Cat Back Exhaust with Tip Inserts $700.00
- Moroso Oil Pan Baffle $120.00
- SS Tig welded oil pick up $110.00
- Recently Buffed and Polished to a dazzeling shine then, put under its Custom Cover
- **18 Months and Over 400 Hours of Labor** - **Free**
- Corner balanced, 50.01% cross weight.
- Two 3 Ring Notebooks with all Paperwork for all upgraded products, Dyno Sheets
- Clear NC Title, no leins.
- SCCA Track Night at Charolotte Roval 1:35.6 Laps
This a poor man's Cayman
Always garaged, never driven in Winter
A very strong stock engine coupled with a very stable, predictable chassis and drive train.
The Wilwood brakes are awesome and have much in reserve as needed.
This car will embarrass many much more expensive "hot" cars, as it will out brake and out corner them. Very light and nimble.
Have bought a new project car, so this one must go.
$24,995.00 or Best Offer.
Last edited by FRW-86; 08-30-2021 at 02:48 PM. Reason: **SOLD****SOLD****SOLD****SOLD**
FRW-86 is offline   Reply With Quote
The Following User Says Thank You to FRW-86 For This Useful Post:
Dzmitry (08-09-2021)
Old 08-07-2021, 01:20 PM   #2
jflogerzi
jflogerzi's Avatar
Is that trans cooler in the stock muffler location? Super clean and we'll sorted. GLWS
2013 Series 10 FRS #553
Old 08-07-2021, 01:50 PM   #3
FRW-86
Yes, the Derale trans cooler fits very nicely where the muffler and heat shield used to be. Used 4 nutserts matched to the cooler mounting holes, so it is easily accessed, and the fan thermostat is all neatly bundled together. There is a removable plug in the outlet aircraft fitting for a 1/8 npt threaded temp sensor if you wanted to add one. All the fluid hoses are wrapped in C/F sleeving and thermally isolated from brake and fuel lines.
Appreciate the feedback.
jflogerzi (08-07-2021)
Old 11-07-2021, 04:41 PM   #4
imnotstas
imnotstas's Avatar
Drives: Asphalt Grey 2015 FRS
Hello is this vehicle still available?
imnotstas is offline   Reply With Quote
Old 11-07-2021, 04:43 PM   #5
FRW-86
Availability Inquiry
If you check the top of the vehicle description, it is marked as *SOLD*
Thanks for checking...
imnotstas (11-07-2021)
Old 11-13-2021, 08:00 PM   #6
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
That price was as steal. Someone should be very happy. Nice, well sorted stock looking sleeper type. My favorite.
jeepmor is offline   Reply With Quote
2017, edelbrock s/c, isc suspension, low miles, toyota 86
Edelbrock Supercharger - run less than 1000 miles - Austin TX srt4evah Engine, Exhaust, Bolt-Ons 16 04-29-2019 03:36 PM
SOLD - TRD/STI/Edelbrock BRZ Limited 18k miles switchlanez Cars for Sale/Trade 4 08-05-2018 11:17 AM
2017 Toyota 86, 860 Edition Under 1K miles thatweirddude25 Cars for Sale/Trade 0 05-08-2018 02:43 PM
FS: The Edelbrock BRZ (2014, 16k miles, 6 Speed) ingenieur_ian Cars for Sale/Trade 6 02-26-2018 09:15 PM
2017 Toyota 86 manual, stock, PA, 5295 miles, $20,900 obo Honesty Cars for Sale/Trade 18 12-26-2017 11:53 AM
