Junior Junior Member
Drives: 2014, Aquamarine
Clicking from Behind Glove Box
2014 Monogram, auto. Easy fix? This is above and to the left of the cabin filter. Lengthier description for any future Since purchasing the FRS, there was this sound as though a vent door was opening/closing behind the glove box roughly 30 seconds after turning off the engine. It got rougher with time as though whatever controls it started to fail. Eventually, I heard a clicking sound with the engine off. Now it's happening even when the engine is running.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Easy fix? Depends on if it's the actuator's that's skipping, or if the door is binding inside the air distribution unit.
Actuator fail often and they're usually easy to replace unless the engineer that designed the system decided to mount it behind the AC unit like I've seen done on cars from GM, Chrysler and Ford. If it's the air door, it's a dash removal. Feel which actuator is skipping by touch, remove it, move the air door end to end with your fingers, if it doesn't bind, replace the actuator. |
| The Following User Says Thank You to RZNT4R For This Useful Post: | sato (08-07-2021) |
#4 | ||
Drives: Dodge Patitas
Sent from my Pixel 3 using Tapatalk Last edited by sato; 08-07-2021 at 12:38 PM. |
Nah, I have a low opinion of dealer techs, but this isn't the thing to make money on. Small jobs with many small parts pay more than big jobs with few parts. Any service manager should know that it's more profitable to lose a tech for an hour on an actuator replacement than to lose him for 8 on a dashboard removal.
Drives: 2014 SSM BRZ
Anyone have the fix for this? I have this same sound going on.
| The Following User Says Thank You to humfrz For This Useful Post: | Packofcrows (07-22-2023) |
#8 | |||
I saw your notification. I actually ended up replacing SU003-02044 to fix this. RZNT4R's advice helped. Quote:
Also, correct. The dealership here quoted me $1,700. They wanted to remove the entire dash so who knows what else they'd mess up. Found this from another thread for additional context: Quote:
| The Following 2 Users Say Thank You to Ryūkotsusei For This Useful Post: | Kauf (07-24-2023) |
hey you, yeah you <3
Drives: 2014 37J FR-S
Crickets and gremlins from my experience!
#10 | |
Drives: 2017 Subaru BRZ Limited Performance
#11 | |
Unfortunately, I ended up doing so! |
| WTB Glove Box | TheDetailer718 | Want-To-Buy Requests | 1 | 05-23-2017 12:29 AM |
| Glove box USB | Eman | Electronics | Audio | NAV | Infotainment | 2 | 01-15-2017 09:34 PM |
| Glove box keypad | Yalsaket | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-20-2015 01:59 PM |
| glove box 12v light? | lbroskee | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-11-2013 10:44 PM |
| Loose Glove Box | Spd229 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-06-2012 01:53 PM |
