Drives: 2013 Scion FR-S Base
I’m running 225/50/r17 + 35 offset on wheels and tires . I bought wheel adapters converting 5x100 to 5x114.3 bolt pattern with 25mm adapters but when I put them on it sticks out way too much. I have stock suspensions and I was wondering if I should get smaller adapters like an 11mm. Or is there any other option that I can do, I’m trying to tuck, or sit flush to finder .
#1819
Drives: Lightning Red Subaru BRZ
When you use bolt pattern adapters they have to come in a certain width to accommodate the nuts that bolt them to the stock hub. Any thinner than that and you are putting yourself in danger. I would recommend selling your adapters and wheels and getting wheels with the proper bolt pattern and offset.
Google wheel adapter failures to see what kind of gamble you take everyday. |
Site Moderator
Drives: ichi 86 Project
+35 offset w 25mm spacer, will make +10 offset. You gotta do 1 of 2 things.
1. Get higher offset wheels. If you want to keep the 25mm spacer, you need minimum of +60 offset to get good flushed. Maybe +58~+56 will work, but might be pushing w the wheel design. 2. Get lower spacer. Even 11mm will put the wheel offset to +24, even putting 3 camber will poke out. Sweet spot for the wheel offset is +32~38 depending on the wheel design AND tire specs. So keep that in mind when you buy the wheels & spacers. |
| Can I fit rims with 5x114 bolt pattern? | Veeoh | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 03-14-2017 06:06 PM |
| Converting 5x100 to 5x114.3? | Danny | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-06-2014 10:23 PM |
| FS NYC: Set of 17x9+22 Multibolt pattern 5x100/5x114.3 STR 518 Matte Black | Vic | Wheels and Tires | 26 | 01-19-2014 08:31 PM |
| bolt pattern is 5x100? | derka-derka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-30-2012 02:58 AM |
