Old 08-03-2021, 06:04 PM   #1
radroach
Drives: car
Akebono brake pad hardware trouble
I put on a set of Akebono pads today, they came with abrutment clips that fit into the caliper, and I had trouble with these. They aren't the same as the factory hardware, and don't clip in as easily. I was able to fit the clips on the front calipers with some fiddling, but the clips for the rear calipers had no way of fitting in, and I had to reuse the factory clips.
Not sure if I should use them like this. Should I order some new clips from Subaru so I know that the fit is right? Or is it more important that I use akebono's shims? Perhaps I bought the wrong akebono pad set from rockauto?
Old 08-22-2021, 03:00 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
In my experience those aftermarket clips don’t fit properly hence are useless.
I just clean up the original clips and reuse them. Of course OEM replacements could be purchased should yours show wear.
Good luck!
Muskoka800 is offline   Reply With Quote
The Following 2 Users Say Thank You to Muskoka800 For This Useful Post:
radroach (08-23-2021), strat61caster (08-22-2021)
Old 08-22-2021, 04:31 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I usually reuse stock clips on aftermarket pad "ears". Just in addition to them using brake dust cleaner, wire brush, and a bit sandpaper, to clean all accumulated crap in those clips and in caliper, when i change pads. (obviously also regrease where needed).
Rarely aftermarket pads don't fit for any other reason but uncleaned crap (but it may happen. in such case one can work on them a bit with file)
Hello everyone, I have a trouble with ecutek mixer624 Software Tuning 2 04-23-2019 01:42 PM
brake hardware ... for primarily track/autox car... Skurj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-30-2018 04:31 PM
CEL trouble steelheart100 Issues | Warranty | Recalls / TSB 9 04-18-2018 04:24 PM
Who sells Stoptech Brake Hardware? ripper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-26-2015 08:56 AM
TF Brake Cooling Kit // Race Pads // Rotors // BBK // Lines // Hardware Touge Factory Brakes, Suspension, Chassis 15 02-17-2015 06:57 PM
