Old 08-01-2021, 06:45 PM   #1
Brock H.
Drives: 2022 BRZ, Red
WTS: 2016 BRZ - STX Full Prep - Hyperblue
2016 BRZ - Hyperblue – VIN: JF1ZCAC1XG9600304 (#304 of 500)
80k Miles
Full STX AutoX Prep – with extras - $27k
Located in Oklahoma City, open to options on moving the car to sale location
Looking to part with my STX prep’d BRZ. Absolutely no mechanical issues at all. Car carried me to 5th in STX at Lincoln Spring Nats, and I’m not that great. Coilovers are bare bones, but are autocross valved and are a good start for seeing what you like/don’t like in a suspension. (IE – it's fast, but it may not be 100% to your liking). The only things left are Coilover/Sways/Differential that are to your specific liking, but what is on there now is pretty standard for a full STX prep Twin.
The car had been well loved by the previous owner and I. All maintenance records are present, and my log book covers the items done at home.
Looking to sell the whole kit at the moment in order to avoid having to move it all separately. Asking prices reflect a discounted full kit purchase, but I can tailor to fit (Only 1 set of wheels, other parts). Don't know if what I'm asking for this is Crazy or not, but the sum total of the parts is much greater than what I'm asking and its a well sorted out build for the platform. This is a very clean car with a rare coloration, so I'm just shooting myself in the foot if I price it as a regular 2016.
If you have questions or want more pics, just let me know.
Notes:
NVH
  • Some higher NVH that usual due to Poly drivetrain bushings (Engine, Trans, and Diff). Once warmed up, they quite down.
  • Poly Suspension bushings contribute to some increased road noise, but is not annoyingly lout to my ear (Subjective, but have taken multiple 4+ hour trips without feeling the need to take a break form the car)
  • CSG-Spec exhaust has a pleasant tone is not loud/has no drone. (sub 90db from outside the car and is pleasant inside the car)
Steering Feel
  • Due to poly suspension bushings and steering rack bushings, the cars steering feel is very direct and quick to react. Take note of this when on highways, especially at higher camber.
Paint/Body condition:
  • Front Bumper: AutoX car, so it has cone marks on the front bumper and a number of rock chips
  • Only 2 small dents of note:
    o Passenger front fender from a tool drop.
    o Passenger door below mirror from door ding (previous owner)
  • Only 2 scratches of note:
    o On the rear bumper guard from loading/unloading AutoX box (should be able to buff out).
    o On the right side of the license plate on the trunk (previous owner)
  • Paint other wise in great condition with only minor surface imperfections and a handful of pock marks on the hood
Mileage breakdown/Engine Health:
  • Of the 80k miles on the car, 65k + where dedicated highway miles. The rest is some City driving and AutoX
  • No over-revs/ aggressive driving outside of AutoX.
  • No Oil consumption whatsoever
  • Essentially babied outside of autoX
Extra’s aside from the parts listed below:
  • Only 1 keyset (new battery, previous owner lost a set)
  • All suspension hardware has been replaced and witness-marked
  • Fuel pump replaced at 79k (recommended maintenance)
  • Front Mud Guards replaced this past spring
  • Front fog light bezel replaced with JDM version (DRL bar and USDM bezel kept and can be put back in)
  • Car capable of -4.5°F/-3.5°R camber (Currently set at -4.3°F/-2.3°R in race config)
  • All Calipers rebuilt using OEM kits (had a rear caliper stick after a brake flush, rebuilt all calipers as preventative maintenance and because I had nothing to do that weekend)
  • Original Control Arms, Suspension, Parts taken off for mods, original header all included (and others) (New Arms where bought for easier Poly Bushing)
  • Other quality of life parts I forget about
Fluids: Enough for a full change of all below fluids is included.
  • Engine oil (Mutol 8100 ECO-LITE 0W-20) changed at 80k miles
  • Trans (Motul Gear 300) and Diff (Motul Gear 300LS) Fluid changed at 76.3k
  • Brake and Clutch Fluid (Motul RBF 600) flushed in the Spring of 2021
Parts list (Installed/Included):
Engine/Power/Exhaust
  • CSG Spec - NA Power Package - Subaru BRZ
    o ACE Header 350 Type-A - Equal Length 4-2-1 Header
    o Jet Hot 2500°F Ceremic Coating
    o Catted Front Pipe
    o Tune (91 and 93 Octane maps)
    o Should be around 190ish WHP
  • Perrin Intake Inlet Hose - 2013-2016 FR-S / BRZ
  • HKS Air Intake Duct - 2013+ FR-S / BRZ
  • CSG Spec - TOURING 86 Competition Exhaust by MXP
  • Braille AGM 11lb Battery Kit
  • Perrin Engine Mount (Poly Bush’d new version)
  • Whiteline Poly Transmission Insert
  • Whiteline Poly Differential insert
  • GReddy Magdrain Magnetic Oil Drain Plug M16x1.5
  • Jackson Racing Dual Radiator / Oil Cooler V2
  • Innovate MTX Digital Oil Pressure & Temp Gauge installed on left Vent
Suspension
  • ProParts USA Custom Megan Racing STX Package (400lb F/R springs)
  • Racer X BRZ Rear Upper Control Arms
  • RacerX Front Lower Control Arm Ball Joints
  • SuperPro Front Lower Control Arm Bushings
  • Whiteline Rear Essential Kit Poly Bushings
  • Whiteline Steering Rack and Pinion bushings
  • Perrin 22mm Front Sway Bar
Wheels/Tires/Brakes
  • Enkei RPF1 17x8 +45
    o Michelin PSS - Front / PS4S - Rear - 225/45R17 (Most of the life left on both)
  • WedSport TC105n Curcuit White 17x9+35
    o Yokohama A052 - 245/40R17 (about 4/32's remain)
  • Carbone Lorraine (CL) - RC5+ - Front
  • Carbotech AX6 - Rear
  • Racer X Master Cylinder Brace
  • Stoptech Slotted Front/Rear Rotors
Brock H. is offline
Old 08-02-2021, 03:36 AM   #2
treydeon13
Drives: Toyota Subaru
80k Miles
Notes:
NVH
Steering Feel
    o Catted Front Pipe
Suspension
Wheels/Tires/Brakes
Still available
treydeon13 is offline
Old 08-02-2021, 07:54 AM   #3
Brock H.
Originally Posted by treydeon13 View Post
Still available
Yes.
Brock H. is offline
Old 08-02-2021, 10:07 PM   #4
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Pics are broken
Plumbus is offline
The Following User Says Thank You to Plumbus For This Useful Post:
Brock H. (08-02-2021)
Old 08-07-2021, 05:36 PM   #5
Brock H.
Vehicle Pending Sale
Brock H. is offline
Old 08-13-2021, 10:18 PM   #6
Brock H.
And Sold
@ichitaka05, Could you please close this thread?
Brock H. is offline
2016 BRZ Series Hyperblue tuna Cars for Sale/Trade 14 02-01-2019 07:56 PM
2016 HyperBlue BRZ rtalich Northwest 8 04-10-2017 09:55 PM
How much did you pay for your 2016 BRZ Series.HyperBlue? one2onejackpot BRZ First-Gen (2012+) — General Topics 9 03-28-2016 01:07 AM
2016 BRZ Series.HyperBlue Announced Veloist BRZ First-Gen (2012+) — General Topics 523 11-05-2015 06:22 PM
Anybody want to buy a 2016 BRZ Series.HyperBlue? Veloist Northern California 0 08-27-2015 01:05 PM
