Old 07-30-2021, 04:59 PM   #1
RadDad2020
How much did I break?
Hey guys, I done goofed a couple nights ago a hit a high curb on a center divider probably between 40-50mph and mangled my front left wheel and some of the parts around it.
Now I'm trying to assess the damage so I can figure out just how bad it really is and what needs to be repaired/replaced to get her on the road again. Had it towed home on a flatbed truck.
I'm a total novice when it comes to fixing cars but this was a salvaged purchase to begin with and I have decided to fix it myself.
Here is my google photos album of the damage:
https://photos.app.goo.gl/Upt5ceBokvYCo5528
From what I can tell, the wheel is obviously f***ed, and the ball joint on the control harm as completely come apart. I think after dislodged from the ball joint, the wheel slammed into the frame, hence the dents in the frame and the frame sized chunk missing from the wheel.
Not sure if I can just replace the ball joint in the control arm, or I need to get the whole arm replaced, and I don't know how to tell if the stabilizer bar or what else might be borked.
Any advice is greatly appreciated! Thanks in advance
RadDad2020 is offline   Reply With Quote
Old 07-30-2021, 05:51 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
That control arm is pretzeled but, fortunately, they are designed to let go before damaging upstream components.
Your upright (hub support? nomenclature) is probably also damaged. Definitely replace the hub (bearing assembly).
Others will chime in with their experiences. Check my sig line for the service manual.
Old 07-30-2021, 05:55 PM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Damage like that goes well beyond just that corner. You will be fighting gremlins well after replacing what you THINK is broken.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 07-30-2021, 06:10 PM   #4
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I'd go ahead and replace the lower control arm completely, it looks like it could have been slightly bent. ($150)
Honestly id slap that on, put a bolt in that hole that's missing one and see how it drives around the block
doesn't look that bad to me, especially for a vehicle that's already salvage title
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
humfrz (07-31-2021)
Old 07-30-2021, 06:52 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is specifically why i have full coverage insurance. i drop it off at a shop, they repair it for a $500 deductible, and i get to complain if they get it wrong.
definitely need to check the mounting point measurements.
Old 07-31-2021, 01:16 AM   #6
humfrz
I second this. Just replace parts till it drives straight and will hold an alignment.
soundman98 (07-31-2021), VIP BRZ (08-02-2021)
Old 08-01-2021, 04:44 PM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
Not as bad as it looks I'd suspect. I've done similar. Replaced the replaceable bits and have had no drama since. Check your engine bay for battery acid. Sometimes it spills out the vent in impacts and syyips paint...
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Break in oil sid94 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 02-09-2018 11:15 AM
New FRS Break In NA_FRS86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 06-01-2015 09:50 PM
Break In New FRS Lunatic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 08-22-2014 03:30 PM
Break In Again? Awstryker Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-07-2013 11:53 AM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
