Old 07-27-2021, 12:52 AM   #1
Bergycheese348
Bergycheese348's Avatar
Drives: TRD Supercharged 2016 FR-S
TRD Japan or US quick shifter
Hello,
As usual, I’m one to window shop for TRD Japan parts (but I end up buying them lol), and this time I’m wanting to see if anyone has any opinions details about the TRD Japan Quick Shifter MS205-18001, and how does it stack up to the US TRD quick shifter PTR54-18130. From what I see, the US version has a claimed 25% less throw and comes with more things besides the shift lever itself, and the JDM version is more about the actual lever and I saw one site say it has a ‘20% shorter throw’. Not sure if I believe that one site, but like with all TRD Japan parts, they never actually give a good description. TIA
Bergycheese348 is offline   Reply With Quote
Old 07-27-2021, 01:31 AM   #2
humfrz
There ain't nutten wrong with the one that came with your car.
(and grapefruits should be eaten in halves)
Old 07-27-2021, 01:48 AM   #3
Bergycheese348
Correct. It is already pretty nice and short, but a short (or quick) shifter is a good modification to have the car feel better. It’s like racing seats in a street car in a way. It helps the driver sit up straight and not focus on trying to stay upright (comparing as both are same weight). Is it needed, not necessarily.
Old 07-27-2021, 02:36 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
That U.S. kit is an actual turd. Stay far away from it. If you want a short shifter, get the JDM TRD, or the STI unit.
Old 07-27-2021, 03:23 AM   #5
gpvecchi
gpvecchi's Avatar
The TRD and STi are different. TRD is 8 mm longer in the lower part, STi 4 mm.
gpvecchi is offline   Reply With Quote
Old 07-27-2021, 07:15 AM   #6
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
I recently got the JDM TRD Short Shifter installed and it's actually lovely. It definitely aids in the spirited driving experience since the gears are smaller. The websites say 20% yes and that makes a huge difference.
Toyota 86 in the building!
Gamace is offline   Reply With Quote
Old 07-31-2021, 04:09 AM   #7
saltywetman
Drives: 2020 Toyota 86 GT 6M
Weren't there reports of issues with the trd usa short shifter modification? replacing the entire shifter unit is always a better idea of bolting shit to the existing setup.
saltywetman is offline   Reply With Quote
Old 07-31-2021, 06:23 PM   #8
LancePower
Drives: 2020 BRZ tS
The one nut could reportedly work itself loose if you didn't loctite it up real good.
Other than that, I think the issues were limited to people who had aftermarket drive shafts.
I loved my TRD Quick Shifter. Might have been my favorite of everything I've driven.
Short, notchy with positive feedback.
LancePower is offline   Reply With Quote
Old 07-31-2021, 09:16 PM   #9
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@Bergycheese348
I've bought and used both the USDM and JDM shifters for extended amounts of time. They both reduce the throw by approximately the same amount.
I tracked and put tons of miles on the USDM without any problems. I later upgraded to the JDM.
For the driving I do and if I had to do it over, I would have gotten and just spent the money once for the JDM shifter from the start
The USDM shifter
  • lower pricepoint, better if you are uncertain if you'll like the upgrade
  • requires a little more diligence and watching to make sure the installation is proper
  • comes with stiffened shifter mount
  • a little less work to install
  • often prone to ratting/more noise
The JDM shifter
  • is more expensive
  • is more sturdy and confident
  • requires a little more work to install.
  • DOES NOT come with a stiffened shifter mount (reuses OEM mount), though you can upgrade if you want
EndlessAzure is offline   Reply With Quote
Old 08-01-2021, 07:57 PM   #10
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So I guess I could give my feedback. I actually have the STI short shifter and TRD quick shifter mated together and it's eh. If I'd do it again, I wouldn't have added the TRD but it does shorten throws and it's notchy.
MS, CSCS, TSAC-F, CPT
jdm, shifter, trd
TRD Quick Shifter FRS_PR Transmission and Driveline 4 05-01-2017 03:16 AM
FS: OEM TRD Quick Shifter NEW IN BOX STS-V Transmission and Driveline 0 07-08-2014 09:11 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
trd quick shifter? tjohnson104 Engine, Exhaust, Transmission 6 01-26-2014 02:37 PM
