Old 07-21-2021, 09:56 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Endurance + boost
Building my BRZ into an endurance car and looking for opinions on safest way to add boost and still offer reliability. Want to keep the FA20, and ideally not change internals. Not looking for gobs of power, but just a little extra kick for the car. Won’t be going wide-body or anything like that.
Anyone endurance racing their 86?
Flat Black VW is offline   Reply With Quote
Old 07-21-2021, 10:18 PM   #2
AT-JeffT
Drives: 14 BRZ SWP
I think the usual endurance best practices apply. 1)Keep it well oiled. 2) Keep it cool. 3)Keep the RPM's low.
Figure out what you need to accomplish those on the 86 platform and you should be good.
AT-JeffT is offline   Reply With Quote
Old 07-22-2021, 08:08 PM   #3
What kind of endurance racing, and at what power level?
Old 07-22-2021, 11:06 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't know anyone racing enduros with forced induction. What series and class? A friend of mine campaigns these cars in WRL.
Sent from my Pixel 4a using Tapatalk
The Following User Says Thank You to Pat For This Useful Post:
femaledog (07-23-2021)
Old 07-23-2021, 01:56 AM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Endurance racing with forced induction is definitely a pursuit of the well funded.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Goingnowherefast (07-23-2021), mrntd (07-23-2021)
Old 07-23-2021, 07:23 AM   #6
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Yeah I don't mean to be a naysayer but this is going to be a very difficult endeavor
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 07-23-2021, 10:11 AM   #7
femaledog
Drives: 2017 BRZ Perf. Pkg.
I only knew of one boosted car doing endurance racing and they want back to naturally aspirated after being plagued by issues.
femaledog is offline   Reply With Quote
Old 07-23-2021, 12:04 PM   #8
Flat Black VW
Well thats disappointing to hear. We had been running an NA miata for awhile, then up to an e30 with an M52 swap, and I was hoping to use the BRZ as a next step. Thinking light boost would help make it a reasonable upgrade from the e30, but sounds like it would need to stay NA or go for a swap.
Old 07-23-2021, 12:20 PM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I would make sure you have everything good in NA form before throwing boost at it.
Old 07-23-2021, 12:33 PM   #10
mrntd
Drives: 2017 Series.yellow BRZ
I would think you would want to see what class you would be in boosted, what the competition is and what else needs to be done to be competitive in the class. Usually boosting is considered a higher end addition after everything thing else has been done.
That being said I think with good cooling for water and oil you could run the Edelbrock SC at low boost safely enough. I know there are people that say I know so and so and they blew up. But what else did they have honing on? NA can blow up too. A company that big is going to provide the car warranty (new car pro installation) thinking they would have to pay for an engine.
mrntd is offline   Reply With Quote
Old 07-23-2021, 12:52 PM   #11
Flat Black VW
Car has been a garage/track car for a few years now. Shes pretty well sorted out at this point.
Kind of the path im thinking. Low boost and stay on top of cooling and see how she does.
No concerns about classing. Car will be built for AER and WRL, AER does qualifying to determine class and WRL use power/weight ratio.
The Following User Says Thank You to Flat Black VW For This Useful Post:
x808drifter (07-23-2021)
Old 07-23-2021, 03:40 PM   #12
rice_classic
If there's not a specific reason play in that power:weight bracket - I've done enough racing (and endurance racing) over the last 17 years to advise you to try and be competitive in a bracket where you can remain NA. But if you're committed then my only input is to account for these realities:
The development cost curve goes up exponentially with every "allowance" a rule set offers and forced induction is major allowance meaning the cost to be competitive adds several zeros to the expense budget. And all that's AFTER you spend the $$$$ to address the added entropy FI introduces.
You are accelerating a mass faster = more fuel costs (plus you can't run as lean = more fuel costs) ​
You are converting more momentum into heat through friction = more consumable costs (brakes, bearings, tires, ball joints).
You are generating more heat in the engine bay, the transmission and the differential - so you will have to add weight (and cost) to cool it - Oil cooling, trans cooling and definitely diff cooling - and that weight - goes back to the first point.
My concern for you is that this will be more of an engineering endeavor vs a racing endeavor and vast majority of your money will be spent away from the racetrack.
PRO86 | WTCC | STL
Old 07-23-2021, 03:45 PM   #13
Autoxer62
I agree completely with the above, you're talking about a lot of engineering besides the engine. But if this is what you really want I'd think about something like this:
Turbo set up for easier boost changes or get a couple pulley sets for a mechanical blower. Roughly speaking I'd want to add a max of 50% more power, which translates nicely to 7 or 8 psi of boost. That means 50% more cooling system and oil cooling, plus an intercooler. E85 would be a plus. Start off with perhaps 5 psi of boost so things don't get out of hand too quickly while you're sorting the rest.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 07-23-2021, 11:49 PM   #14
rice_classic
For power, yes. For endurance racing I would think MPGs matters more. The fuel burn rate of E85 is much too high and therefore you either have to run a larger fuel cell and more fuel weight which could lead to longer stops because more fuel has to be put in (depending on how you fill). Being able to run the maximum stint time with the least fuel on board is ideal. E85 is the enemy of fuel economy.
PRO86 | WTCC | STL
WTB AP Racing Endurance Brake Kit kuczynskika Want-To-Buy Requests 0 07-17-2017 01:41 AM
Gear One's Endurance BRZ, She can take a hit! Gear_One_Performance Member's Car Journals 74 06-25-2016 02:03 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
frs endurance race frs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-26-2012 09:53 PM
