Drives: 2013 brz
Clutch buzz/noise after installing a new one?
Hello,
I recently had my whole clutch replaced by a reputable shop, and notice a noise and almost slight vibration when driving spirited. If I am driving normal and keeping it under 3.5k RPM, everything is quiet and fine. It is only when I try shifting above 3.5k-4k where I notice a noise and feel something in the clutch when press it in to shift. The noise is not loud but noticeable and I am just wondering if that's bad ![]() From my understanding using aftermarket clutch parts causes a noise over true dealer oem clutch replacement parts..Which is why I ordered everything from the dealer, except the flywheel . Would only the flywheel being exedy aftermarket (oem spec) be the cause of this? Did the shop that installed the clutch do something wrong? Thanks
not playing cards
Especially if you feel it in your clutch foot, something is wrong. Pressure plate mount screw missing? Something's out of balance. If true, very bad in the not so long run.
| Odd noise after installing coilovers and endlinks | CSkap21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-28-2019 07:53 AM |
| Clutch creaking noise (not the clutch fork one...) | treminaor | Issues | Warranty | Recalls / TSB | 59 | 10-23-2017 01:53 AM |
| 2013 FRS buzz when clutch partially engaged/slipping | bemgikim | Issues | Warranty | Recalls / TSB | 13 | 05-29-2017 09:47 PM |
| Clunking noise after installing springs | JACK 8URT0N | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 03-28-2015 03:37 PM |
| What's a resonable labor price for installing a new clutch? | mike the snake | Engine, Exhaust, Transmission | 16 | 11-29-2013 02:42 PM |
