Drives: 2016 Scion FRS Halo
I drive a manual 2016 Scion FRS with 24,000 miles and my clutch pedal seems to not be smooth when pressing and letting off. When I first bought the car brand new with 8 miles on it, it was smooth, but at roughly 14,000 miles, it started to lose it's smoothness.
It's hard to describe, but when I press it down and let it back up, it just doesn't have that brand new butter smooth feeling. I don't know how to describe it. When you press it and let off completely you can feel very small and subtle disturbances throughout the motion. It feels as though maybe the pedal or some mechanism is getting worn out or been through heavily manipulation over the course of being used constantly. But overall the clutch pedal and the clutch operate perfectly fine. It's just a feel thing for me. It's not that big of a deal since everything works perfectly fine, but it just annoys me since I daily drive in a big city and I'm constantly on the clutch all the time. I wish for it to be smooth just like the first day I bought the car. What could be the problem and how can I fix it to be smooth again? Edit #1: Needed to clarify that the clutch pedal was working perfectly when I initially bought it, up to 14,000 miles Edit #2: I forgot to mention that when my car heats up and I have the heat on and it shoots into the foot wells for at least 10-15 minutes the problem goes away completely. The clutch pedal ends up being butter smooth again. Last edited by ghostzfh; 07-16-2021 at 12:01 PM. Reason: See clarifications |
not playing cards
Fatal flaw in the design and/or factory lube. Lube melts, separates. It's also sticky and picks up dust from the disc. That crap grinds into the quill and chafes it.
The real fix is to drop the trans and replace worn components. I seem to be having good luck with graphite/molybdenum grease in the main fork pivot but not sure long-term because covid. Haven't been driving it much.
#3 | |
not playing cards
Yes, yes.
#5 | |
![]() OK, short of a major operation, may I suggest you give a squirt of silicone spray to any moving clutch parts that you can see. That may not "fix" it, but at least you will have tried - ![]() Also, you may wish to try the @Ultramaroon method: Quick & dirty: from @Ultramaroon 1. Detach the slave cylinder. Leave the hydraulics alone. 2. Remove the dust boot from the fork. 3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip. 4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger. 5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own. 6. Put a dab of grease in the top pivot where the slave pin goes. 7. Reassemble. Bubba suggests to lube that stupid little spring under the dash that hooks into the clutches working arms. Well, hell, it worked with the squeaky screen door springs, back in the day. - |
Famous Potatoes
Drives: '15 ultramarine
You say, "But overall the clutch pedal and the clutch operate perfectly fine."
So, how much experience so you have with cars? |
@humfrz - Please see my newest edits in the first part
@Sapphireho - Not much...This is my first car. Had it for 5 years so far... |
#8 | |
@humfrz
@Ultramaroon I forgot to mention that when my car heats up and I have the heat on and it shoots into the foot wells for at least 10-15 minutes the problem goes away completely. The clutch pedal ends up being butter smooth again. Does this change the source of the problem? |
#10 |
not playing cards
Coincidence only. The sticky clutch fork is worst when it's cold.
#11 | ||
That maintenance by the shop made my clutch pedal feel like new again. Not sure if they re-lubed it or not but it feels nice.
Instagram: @spike.grc
#12 |
@Ultramaroon
Are there any picture based step by step guides to greasing the clutch fork, pivot/ball, etc.? I'm a noob to mechanic stuff. |
#13 |
not playing cards
Here's a view of the clutch fork (and stuff) from the service manual.
Look for it in context by starting with the link in my sig line. Here's another cutaway view I marked up a long time ago. I don't have one but others seem to have good results with the Verus clutch fork. The OEM design is just a crappy fail in a few ways. You could get away with a dab of grease in the pivot for a while but it will come back, and it will progressively get worse as the socket wears.
#14 | |
| Tags |
| clutch pedal, wear |
| Brake pedal feel issue | Open Loop | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 01-03-2020 03:38 AM |
| VOTE: Your Transmission 6MT? Butter smooth? -or- Problems? | hmong337 | Engine, Exhaust, Transmission | 111 | 07-27-2016 09:59 PM |
| How to fix light feel with the clutch pedal? | hot86lova | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-04-2014 01:06 AM |
| Transmission just doesn't feel right (since day 1 bought with 83 miles) | GhostShield | Issues | Warranty | Recalls / TSB | 90 | 04-15-2014 07:51 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 12:29 PM |
