Old 07-02-2021, 08:03 PM   #1
Teppka
Drives: Subaru BRZ
Can custom tune get rid of torque dip on stock headers/exhaust?
Not planing to change any engine/exhaust hardware for a few years and am wandering if software tuning can solve or at least considerably improve torque dip? Tune will be custom, done by the tuner, no ready presets.
Thanks.
Teppka is offline   Reply With Quote
Old 07-02-2021, 08:34 PM   #2
jflogerzi
jflogerzi's Avatar
OFT can help but on stock everything without e85 that dip will still be there. It will be mitigated but not gone?
2013 Series 10 FRS #553
Old 07-02-2021, 11:14 PM   #3
Lantanafrs2
Drives: 2013 frs red
Not as far as I know
Old 07-02-2021, 11:57 PM   #4
PulsarBeeerz
Drives: JRSC BRZ SOLD
No, it is a hardware issue.
PulsarBeeerz is offline   Reply With Quote
Old 07-03-2021, 01:40 AM   #5
DarkSunrise
DarkSunrise's Avatar
This is about what you can expect with a nearly stock car and a tune:
You reduce the duration of the torque dip by 500 rpm (3200-4200 vs. 3200-4700 rpm).
Only you can say whether you consider that a considerable improvement or not.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
PerCompLLC (02-11-2023), Teppka (07-03-2021)
Old 07-03-2021, 01:51 AM   #6
Teppka
Drives: Subaru BRZ
Thanks. Would changing headers along with really make a difference? Changing headers only with rest of the exhaust remaining stock.
Old 07-03-2021, 02:20 AM   #7
DarkSunrise
Short answer is yes. The Ace and JDL 4-2-1 headers both add significant power in that 3200-4700 RPM band but you'll need a custom tune (which it sounds like you're planning to do anyway).
Alternatively nearly any catless header + E85 (if you have access to it) will eliminate the torque dip as well.
2022 BRZ Build
2013 FR-S Build
Old 07-03-2021, 11:25 AM   #8
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Not doing headers is a waste. It makes a huge difference. All I have is headers and a dyno tune by Zach and the car just woke up. HUGE difference
Old 07-03-2021, 11:38 AM   #9
jflogerzi
jflogerzi's Avatar
Agree with others. Get tune and header and leave everything else. I just drove my car stock at my local time attack/go kart track. It's a pretty low speed course and a header a tune was worth just about a second or a bit more. Normal laps for me are low 46s or high 45s. Was in low 47s and high 46s. 100% worth it
Old 07-04-2021, 04:52 AM   #10
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
I went with catless UEL headers and overpipe (came as a kit) and left the rest of the exhaust bone stock. K & N drop in. Stage 2+ OFT tune.
It makes a real difference to the car, as other have said it wakes the car up. Really happy with it.
In terms of power and torque there is not much to be had after you get past the front pipe and even the replacing the front pipe won't yield much apart from more noise.
sneaky_pete is offline   Reply With Quote
Old 07-04-2021, 07:06 AM   #11
saltywetman
Drives: 2020 Toyota 86 GT 6M
Anything after headers is more for sound unless you boost the car. Header + tune is pretty much a must have mid for the first gen twins after better tires
saltywetman is offline   Reply With Quote
Old 07-08-2021, 04:15 AM   #12
Teppka
Drives: Subaru BRZ
And would changing headers + tune eliminate the torque dip completely? I read controversial opinions, some say it will, some it will not. Also cat vs castles, something I don't really get. If bought with cat, assuming it's an aftermarket product can it malfunction in future? In my country I will pass emission tests without cst just fine.
Old 07-08-2021, 09:44 AM   #13
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Don't think so deep into it. Is "looking at a graph with an eliminated torque dip" what you're looking for? Or are you just looking for a nice improvement in driving and power? A simple answer is, it more or less eliminates the dip - at least it FEELS like it does, and that's all that should matter to you.
Yes, ALL cats can malfunction over time, no cat lasts forever. Cat-less is the better way to go if your emission rules allow it or you can get past it, as there will be a little more power to gain.
Dzmitry is offline   Reply With Quote
Old 07-08-2021, 09:29 PM   #14
Teppka
Drives: Subaru BRZ
Well, some part, or all of the FEEL maybe a placebo effect after tuning/changing headers. Specially considering the possible hp/torque boost as well as torque dip improvement values are minor. It's still an investment and I'd rather trust boring dyno data.
stage 2 tune stock headers EvolutionRevolution Software Tuning 8 02-13-2020 11:31 AM
New car to me drift office tune tomie uel headers stock exhaust uwrasta Engine, Exhaust, Transmission 9 03-29-2017 01:00 PM
Going back to stock catback with a custom tune? theman233 Engine, Exhaust, Transmission 2 03-08-2017 10:05 AM
Got a custom tune on the FRS. What happens if i add aftermarket headers after? AceNiNe Software Tuning 9 03-13-2014 11:37 AM
Got a custom tune on the FRS. What happens if i add aftermarket headers after? AceNiNe Software Tuning 5 03-02-2014 10:50 PM
