Old 07-02-2021, 03:37 PM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Inner CV Joint design - why not Tripod?
I raced Hondas for a dozen or so years and most I've worked on the inner CV joint used a Tripod design which effectively never failed.
Considering how little work the rear axles on our cars do vs a FWD car - I was blown away to find out that our inner joints used a Rrzeppa joint.
For reference
https://www.kmpdrivetrain.com/drives...-rzeppa-joint/
Originally Posted by fromKMP
Race cars
For race cars, there are other benefits to the tripod joint. The tripod joint is more compact than the Rzeppa joint. The result is that a tripod joint of the same size as a Rzeppa joint is stronger or a tripod joint with the same strength as the Rzeppa joint is smaller and lighter. Sometimes, when space is at a premium, switching to a tripod joint means a stronger driveshaft can be made without using more space.
Does anyone know if any shops, tuner or individual has gone down the road of converting the inner joint to a Tripod?
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Code Monkey (07-02-2021), Ultramaroon (07-02-2021)
Old 07-02-2021, 03:54 PM   #2
ka-t_240
I have never taken them apart, or done failure analysis on them, but I have helped change more axles on FWD Hondas at the track than I can count. Is that not where they fail?
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
rice_classic (07-02-2021)
Old 07-02-2021, 04:13 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I've considered it for a custom solution but my inners are tight. All the lash is in the outer joints.
Bone stock suspension. They're perfectly ok, just annoyingly sloppy.
Old 07-02-2021, 05:20 PM   #4
rice_classic
FWD failures are generally the outboard joint.
PRO86 | WTCC | STL
Old 07-03-2021, 12:47 AM   #5
rice_classic
I suppose I could just call DSS and see if this is something they have input on.
PRO86 | WTCC | STL
Old 07-10-2021, 12:08 PM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I'd be interested in hearing what DSS has to say.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
"OEM" Cargo (Tripod) Net FUN BRZ Northern California 15 05-15-2014 11:37 AM
Nikon D7100 w/ 18-105mm Lens, Bag and Tripod Michael Miscellaneous 0 04-02-2014 03:23 PM
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 58 04-11-2011 09:03 PM
