Drives: car
2022 seats in a first gen?
My first gen seats are still good, but the new seats sure look comfy. Can they swap into the older cars?
TRACKBREAD
Maybe
ProCrastinationConsultant
my mommy says i can do anything if i put my mind to it.
i also have a sawzall, a welder, and a crowbar. you can too!
TRACKBREAD
Apparently the bolted interfaces are the same, but they put the seats closer together. Might be tight around the 1st Gen center console.
Rust bucket enthusiast
Reviving, curious about this.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Jdmjunkie (06-18-2022) |
Drives: 2014 GT86
New they probably cost too much. Not sure if number of 2022 cars in breakeryards is high enough to source them cheaper. But if paying new-oe prices, then i'd probably go for some reclining recaros or similar, for even better looks/side supporting.
| The Following User Says Thank You to churchx For This Useful Post: | Teseo (06-19-2022) |
Sort of off topic, but as I was rebuckling my seatbelt loop for the 100,000th time I had wondered if they improved them in the new model. Looking at the pictures above it appears they did not, still using a snap loop.
Is that accurate, and if so do they work any better than the ones in my '13?
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
Drives: Subaru BRZ
^ Same as gen 1.
Drives: X5 35d, D90, CX-5 Turbo
Aren't the Side Impact Airbags in the seats? I'd be concerned about compatibility and if they would deploy when needed..
#10 |
Drives: 2018 brz
Gen 2 seats fit in gen 1, I swapped mine just to see. Subaru changed the seat buckle, so you will need to transfer over the gen 1 seat belt buckle to the gen 2 seat before installing.
| The Following 8 Users Say Thank You to ravenwrx For This Useful Post: | brandonblt2 (04-06-2023), Dadhawk (07-21-2022), DarkPira7e (07-21-2022), Decep (07-21-2022), Ohio Enthusiast (07-21-2022), sftateofmind (01-21-2023), Tatsu333 (04-06-2023), tobin (07-21-2022) |
#11 | |
Thank you for this! How do they feel, comparatively? Does it trigger the SRS light?
#12 |
Drives: 2018 brz
SRS plugs right in, and the gen 1 seats have better lumbar support, gen 2 seats have literally no lumbar support and less padding in the cushions, but are more bolstered in the thigh area. I still prefer the gen 2 seats for what it worth.
| The Following 3 Users Say Thank You to ravenwrx For This Useful Post: |
#13 |
Drives: 2017 Toyota 86
So gen 2 seats are plug and play on gen 1?(besides the seat belt buckle) and the occupancy sensor on passenger seat works fine or did you have to move that over from the gen 1 seats?
#14 |
Drives: English, French, Swedish & Japanese
For what its worth, I find the Gen 1 (2017) seats better. More lumbar support as noted above and they sit quite a bit lower in the car.
| Lexus LF-NX Concept / The All-New 2022 Lexus NX | DIM | Other Vehicles & General Automotive Discussions | 34 | 06-11-2021 11:20 PM |
| 2022 992 GT3 | Kiske | Other Vehicles & General Automotive Discussions | 29 | 02-23-2021 07:22 AM |
| 2022 BRZ | g e | BRZ Second-Gen (2022+) General Topics | 110 | 11-18-2020 09:15 AM |
| Lowering Stock Seats/Aftermarket Seats. Headroom Needed! | RobGT86 | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-17-2019 05:53 PM |
| Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale | Sehwan Kim | Interior Parts (Incl. Lighting) | 1 | 01-28-2015 07:35 AM |
