Old 06-16-2021, 03:48 PM   #1
tylerthegoat
Drives: FRS
Uncomfortable seats
Hey everyone.
I just purchased a 2016 Scion FRS and am having a lot of trouble getting comfortable in the seats. I'm a pretty tall guy (6'4 ~200 pounds) and my waist width is 36". My main concern is that my thighs/hamstrings tend to rest against the side seat bolsters and after 10-15 minutes I get burning and stabbing pains throughout my legs. Naturally, this is a cause for concern and I have since been trying to figure out a way to prevent this from happening.
I purchased a seat cushion from Amazon but it surprisingly does not seem to help at all (if anything, it just makes me sweat a lot).
I've done a lot of research the past couple of days regarding modifications I can make to either make my seat more comfortable or simply replace the stock seat with an aftermarket seat. It seems like other people have had similar problems and have went to an upholstery shop to replace the firm foam with memory foam, but after getting a quote and talking to the shop owner of a local upholstery shop, he said that while it is a common complaint, it is largely a coin toss whether it helps or not. He said that about half of his customers come back after a couple of days and claim the memory foam helped very little.
I appreciated his honesty, but I am now slightly worried that I'm stuck with a car that has the worst seats I've ever sat in. This is not something that I noticed during my ~20 minute test drive. If anything, I was amazed that I was able to sit in the car with plenty of legroom and headroom. I did not pay much attention to the way the seat was designed.
Does anyone have any recommendations or has anyone gone through something similar? Luckily, the place I purchased the car from has a return policy, and I have a few more days before I'm stuck with the car. I'm leaning towards returning the car as I'm in pretty bad pain, but I really enjoy the way it drives and it is one of the cleanest cars I've ever seen.
Thanks in advance.
tylerthegoat is offline   Reply With Quote
Old 06-16-2021, 03:55 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Are you slouching? I find it hard to believe that the pressure on your hamstrings is so large it causes pain. I have experienced pain in the back of my leg because of an intervertebral disc pinching the sciatic nerve because I was slouching. Make sure your back is straight and there’s an arch in your lower back, that helped a lot for me. I ended up adding an aftermarket lumbar support to my seat.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
alphasaur (06-17-2021), mrntd (06-18-2021)
Old 06-16-2021, 03:55 PM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like "buyer's remorse"..
The Following User Says Thank You to JD001 For This Useful Post:
spike021 (06-16-2021)
Old 06-16-2021, 04:10 PM   #4
Ashikabi
Ashikabi's Avatar
Sounds like a you problem, not a seat problem. I don't believe the bolster touching your leg would actually cause these symptoms. Much more likely, your back is messed up because of a tight posterior chain and hip flexors. It wasn't evident in your last car because the you were accustomed to the seating position. Get stretched out and your pain will likely disappear. I've dealt with back pain many times over my professional career and it was ALWAYS muscle related.
That includes back pain I attributed to my FRS. My lower body is very tense while driving it, which pulls my lower back out of place, eventually causing significant discomfort. Perhaps try stretching calves, ham strings, glutes, and hip flexors multiple times a day until the last minute you have to return the car. Make a decision then. You can't stretch all the way out in one session, that's why I recommend taking as many days as possible
Old 06-16-2021, 04:16 PM   #5
tylerthegoat
Drives: FRS
Nope, I have pretty good posture and sit upright. Slouching is uncomfortable for me as I have slight scoliosis and work out to prevent my lower back from hurting. It's surprising to me too because it's the first time I've ever experienced anything like this from a car seat. I'm coming from a Speed3 and I wish I could swap those seats with the ones in the FRS as they were miles more comfortable for me.
I actually sit at my desk with a lumbar support cushion for my chair and so I'll try and put that in my car and see if it helps. Thanks.
Ha. I promise you it's not. I'm actually enjoying the hell out of the car aside from the seats. If only Recaros were cheaper...
This is possible. I do have pretty tight hamstrings and calves according to my doctor. Thanks.
The Following 2 Users Say Thank You to tylerthegoat For This Useful Post:
Ultramaroon (06-16-2021), Yoshoobaroo (06-16-2021)
Old 06-16-2021, 04:31 PM   #6
Ashikabi
Ashikabi's Avatar
Sure. Hope you get it figured out
Old 06-16-2021, 04:54 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
move the seat forward, at least 4 clicks. does the pain go away?
Old 06-16-2021, 04:57 PM   #8
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
+1 to try a lumbar pillow. There is ZERO lumbar support or adjustment on the stock seats, and a pillow changed my overall posture in the car for the better. It will also scootch you far enough forward that your legs may no longer be pressed against the bolsters, as the seat widens a tiny bit from front to back.
Even if your back isn't hurting, your legs could be hurting because your back is not supported properly.
I'm also 6'-4" and ~200 lbs for the record with ~34" waist.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 06-16-2021, 06:59 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Man, all us tall people waiting for that plus-size Miata alternative! Yay!
Interesting deal with the hammys. What's your inseam? Are you all torso?
6'5" um, heavy AF, 37" inseam. Super comfy in the seats. Most comfortable I've ever felt.
Old 06-16-2021, 07:09 PM   #10
6'5" .
You missed a foot!
Ash_89 (06-18-2021), NoHaveMSG (06-17-2021), spike021 (06-16-2021), Ultramaroon (06-16-2021)
Old 06-16-2021, 07:12 PM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
This thread is giving me flashbacks.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
spike021 (06-16-2021), Ultramaroon (06-16-2021), wolffbite (06-17-2021)
Old 06-16-2021, 07:12 PM   #12
sunami88
Drives: 2016 Hot Lava FR-S
That's a new take on the 'ol Apple slogan: "You're sitting wrong"
sunami88 is offline   Reply With Quote
Old 06-16-2021, 07:29 PM   #13
Ashikabi
Ashikabi's Avatar
It is what it is
Old 06-16-2021, 07:31 PM   #14
tylerthegoat
Drives: FRS
Interesting suggestion. I sit with the seat almost maxed out (probably about a click or two away from the max). Will try this out tonight and report back.
Oh wow, we almost have the exact same body. Will definitely try a lumbar pillow and report back.
It is indeed very strange. My inseam is 32". I would say I'm slightly more legs than torso. The fact that you're heavier and taller and still manage to be comfortable gives me hope.
You missed a foot!
This gave me a good chuckle. That's probably how I look sitting in my car.
Did you go through something similar?
I just might be sitting wrong lol.
Thanks everyone for the suggestions. I didn't expect this thread to blow up like this. I'll definitely give it a couple of days and report back with any updates.
Lowering Stock Seats/Aftermarket Seats. Headroom Needed! RobGT86 Cosmetic Modification (Interior/Exterior/Lighting) 17 01-17-2019 05:53 PM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 07:35 AM
FT: (SOCAL ONLY) FR-S ALL LEATHER SEATS FOR YOUR STOCK CLOTH SEATS ix2vi Interior Parts (Incl. Lighting) 12 07-06-2014 04:49 AM
SOLD: Used (But Like New Cond.) Stock FR-S Seats w/ rails (Both Seats) Vicious LED Interior Parts (Incl. Lighting) 16 07-21-2013 06:45 PM
