Old 06-15-2021, 03:30 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Spark plugs
2014 running E85, but I may have to go back to 93 since E85 is hard to get here. 50K mile DD and I'm about to change plugs. From what I read here, most use the OEM. Is there a better choice?
Qwimby1 is offline   Reply With Quote
Old 06-16-2021, 02:05 AM   #2
Olson1288
Olson1288's Avatar
Drives: 2014 DGM BRZ Turbo
I believe HKS makes a set that is considered "one step colder" but in reality it makes little to no difference. I run OEM and I'm turbo'd and they work perfectly, don't change the gap. Order the Toyota version rather than Subaru and they come out to be much cheaper.
Olson1288 is offline   Reply With Quote
The Following 2 Users Say Thank You to Olson1288 For This Useful Post:
Qwimby1 (06-16-2021), soundman98 (06-17-2021)
Old 06-16-2021, 07:06 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
My advice: Skip the plugs altogether until you drop an igniter. Bet they'll last 100 Kmi or longer.
humfrz (06-17-2021)
Old 06-17-2021, 12:09 AM   #4
humfrz
You lost me there, old man -
Ultramaroon (06-17-2021)
Old 06-17-2021, 12:23 AM   #5
Ultramaroon
not playing cards
Coil pack? When the iridium tips in the plugs burn, they make the igniters work extra hard. Igniters already don't last forever so it doesn't matter. Might as well do them all in one fell swoop.
...IMHO
humfrz (06-17-2021)
Old 06-17-2021, 12:34 AM   #6
Brz-123
...IMHO
The coil packs seem to go only when there is under bonnet engine heat build up, like track days or the up and over style ft86club styled aftermarket manifold.
Changing them together is a big expense and if done , potentially delicious tuning ones?
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 06-17-2021, 12:41 AM   #7
humfrz
...IMHO
Well, I'll be darned, ol Ultramaroon learnt me something today -
Old 06-17-2021, 12:45 AM   #8
Ultramaroon
not playing cards
Nope. They also have a limited lifespan. I've played that stupid onesy-twosey game with three completely different engines over the years. All over 100 Kmi, all just people movers. Track abuse (yes, I participate, and I said it) accelerates their demise.
Normally, they're like headlight bulbs. When the first one goes, just suck it up and change them all.
Brz-123 (06-25-2021)
Old 06-24-2021, 04:25 PM   #9
KN0W
KN0W's Avatar
Drives: 2013 Scion FR-S 10
FWIW I had a coil pack on my passenger side die a year and a half ago.
Replaced that one coil and I have not had any issues since.
I abuse the car regularly, although maybe not as much as those who have racetracks to go to.
its nice to know that I can just get the toyota plugs and not worry about gapping them.
I am supposed to do that sometime soon, but im not sure how Im supposed to get the tool in there even if I jack up the motor a fair bit. (the tool for the plugs)
KN0W is offline   Reply With Quote
Old 06-25-2021, 01:56 AM   #10
Ultramaroon
not playing cards
How many miles on the car? #3 tends to go prematurely because of the overpipe.
Old 06-25-2021, 02:12 AM   #11
Brz-123
Are the aftermarket delicious Tuning ones any better?
And IIRC MY15 onwards had a revised set which are reliable compared to the ones before
Old 06-25-2021, 02:23 AM   #12
Ultramaroon
not playing cards
I don't know. If there's truth to the factory change I imagine they'd be a sub for earlier model years. Personally, I'd try those before going aftermarket. That's just my mistrust for aftermarket talking there.
Qwimby1 (06-26-2021)
Old 06-25-2021, 02:55 AM   #13
KN0W
KN0W's Avatar
I believe this was when I had about 35-40K. It was a few years ago now.
at the time the header and overpipe were the factory ones.
The Following User Says Thank You to KN0W For This Useful Post:
Ultramaroon (06-25-2021)
Old 06-25-2021, 03:27 AM   #14
Brz-123
Unfortunately different wiring harness and connector , so won't be Reverse compatibile. Check the links for reference , that's all..
https://www.delicioustuning.com/node...QaAgYzEALw_wcB
https://www.delicioustuning.com/node/958
The Following User Says Thank You to Brz-123 For This Useful Post:
Spark Plugs FR-S2GT86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-16-2020 02:23 AM
OEM Spark Plugs - NIB JohnPayneFun Mechanical Maintenance and Tools 2 04-20-2020 03:03 PM
spark plugs Legend@wheels Engine, Exhaust, Transmission 3 12-12-2018 12:13 AM
How to gap spark plugs Strife26 Engine, Exhaust, Transmission 38 01-09-2018 01:06 AM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
