Old 06-13-2021, 02:58 PM   #1
Kai Uhl
Kai Uhl's Avatar
FS: Widebody 2013 Scion FRS - (Los Angeles / Socal)
68,XXX miles but will slightly increase as this is my daily. Clean title. Paid off / title in hand. Original owner, purchased new in 2013. Original 2 keys included.
Exterior:
Flares paint matched and blended to quarter panels by LTMW. Front bumper paint matched by TL autobody
Authentic RBv2 flares
2017+ 86 front end conversion (86 front bumper, 86 headlights)
TOMs taillights USDM version
Seibon carbon fender vents
Godspeed rear tow hook
Raceseng tow hook (uninstalled)
Beatsonic shark fin antenna
Wheels / suspension / brakes
TE37sl pressed graphite - 18x10.5 +15 square setup
36mm 5x114.3 conversion adapters, 50mm 5x114.3m conversion adapters
Federal RS Pro - 255/35, 265/35
Fortune auto coilovers w/ swift springs
Winmax w3 front brake pads w4 rear pads. Motul high temp brake fluid
Stainless steel brake lines
Motul RBF 660 brake fluid
Performance / engine/ drivetrain:
Versus clutch fork and pivot bearing
ACT HDSS clutch w/ lightweight flywheel. Installed at 50k
Catless front pipe
Invidia r400 catback exhaust
Interior:
NRG short hub
NRG Quick release
Personal neo grinta steering wheel
Velox pedal spacer
Wink mirror
Maintenance
Valve spring recall completed at Longo Toyota @ 50k miles. Replaced spark plugs and serpentine / accessory belt at same time of recall. No issues since
Oil change every 5k miles
Transmission and diff fluid change @50k miles with Motul 300v
Driver’s side axle replaced at 40k
Cons
Exterior – 8.5-9/10 – paint match is spot on but widebody kit and flares do show some signs of wear. Small dent on driver’s side rocker panel (can be covered with side skirt)
Electronics on keys don’t work
Does not occur often but 1st gear lockout on clutch (common issue on ACT clutches) stock clutch will be included
No test drives without cash in hand. Price is $17.5k OBO / negotiable. -$2.5k if you don’t want the TE37’s with tires (must bring your own wheels)
I'm not active on this forum so if you're interested, please text me at (951)-808-2549 for more info / pics
Kai Uhl is offline   Reply With Quote
Old 06-20-2021, 01:45 AM   #2
Kai Uhl
Kai Uhl's Avatar
ASKING PRICE DROP to $17.5k. -$2.5k if you don't want the TEs
Old 06-20-2021, 02:39 AM   #3
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Didn’t know the RS-Pro tyres existed. Look cool. They any good?
Best of luck with the sale.
ACT86 is offline   Reply With Quote
Old 06-25-2021, 01:23 AM   #4
Kai Uhl
Kai Uhl's Avatar
Pretty similar and an overall improvement compared to the RS-RRs. Haven't got to test them on the track but from what i've heard, same to similar grip but without the excessive tire noise of the RS-RRs
Old 06-29-2021, 05:32 PM   #5
sp
Drives: None
Can you post up any pics? is this still available?
sp is offline   Reply With Quote
FS: 2013 Scion FR-S SoCal carlossanchez89 Cars for Sale/Trade 1 02-23-2020 12:56 AM
2013 Scion FR-S Custom Widebody SHELL pleong Cars for Sale/Trade 5 03-19-2019 10:56 PM
FOR SALE! 2013 Scion FRS 10 Series 86 BRZ Widebody Turbo'd Malekkb24 Southern California 0 03-19-2019 02:41 PM
FS (SoCal): 2013 Scion FR-S 17K rawr Cars for Sale/Trade 2 07-06-2016 07:51 PM
