Howdy
Drives: 2020 BRZ PP
Hi All,
I just had an Edelbrock SC installed and love the tune (tuner is well versed with Subaru), but I’m worried the cold start rpm is too high and maybe causing wear during the first 30-45 seconds; about 2.4k RPM
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
Just get tuner to drop cold idle to 1800 no idea why you would need it to rev that high on cold start generally i use 1200 rpm max idle
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Arthur-A (06-11-2021), BrahmaBull1990 (06-11-2021) |
Howdy
Drives: 2020 BRZ PP
Is this safe? The cold start is about 30-40 seconds. More just annoying right now
Drives: 17 Asphalt 86
It's fine. The cold start is just to heat up the cats. With your catless header you need at most 1200rpm on start. One hack I did prior to the OFT cold start delete was to put the car into gear and move it back and forth upon start. That would disable the cold start.
| The Following User Says Thank You to RToyo86 For This Useful Post: | BrahmaBull1990 (06-11-2021) |
#5 | |
Howdy
Drives: 2020 BRZ PP
| Cold cold(under 30dg) start sounds super weird | vladniko86 | Engine, Exhaust, Transmission | 9 | 11-19-2020 09:08 PM |
| Question about cold start knock, battery | radroach | Issues | Warranty | Recalls / TSB | 24 | 12-17-2016 08:24 AM |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold start question | ggiddix | Engine, Exhaust, Transmission | 8 | 02-06-2015 10:27 PM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
