Drives: BRZ Limited
Brake Light Constantly On or Constantly Off
Hey everyone,
I have an issue where when the light selection indicator is set to auto, the brake lights do not work and do not illuminate when pressed or when the e-brake is pulled. Conversely, when the light selection indicator is set to parking/accessory, then the brake lights stay illuminated, even when the brake pedal is not pressed or the e-brake is not pulled. When the light selection indicator is set to headlights, it is the same as when it is set to parking—the brake light is on and stays illuminate, even when not pressed. I thought it was an issue with the brake light switch so I have tried adjusting it, and have even tested it with it pulled out, but the results are always the same—brake lights always on when set to headlight or parking, and brake lights always off when set to auto, no matter the input of the brake pedal. Anyone have any ideas? Is it a faulty brake light switch or something else? Thanks, |
30 minute maintenance
Drives: My18 wrxsti
It sounds like the problem is in the tail lights. Are the tail lights standard.
Drives: BRZ Limited
The taillights are aftermarket, but there weren't any issues with them before. The issue right now is not only limited to the taillights, but also the third brake light and the fourth brake light. The taillights and third brake light were all in working order—perhaps the wiring of the fourth brake light is causing the issue?
The fourth brake light was installed a month or two ago so it is the latest addition. Of course, there's no way for me to have known about the brake light issue until a friend who was driving behind me pointed it out today. I will try disconnecting the 4th brake light tomorrow and see if there are any changes. |
#4 | |
Drives: 2018 Subaru BRZ Limited with PP
| The Following User Says Thank You to Dzmitry For This Useful Post: | NoHaveMSG (06-12-2021) |
Drives: Crapcan
Sounds like you have that 4th brake light tapped into the running lights, or it is back feeding.
ProCrastinationConsultant
i throw my tool bag on the brake pedal so i can check these kinds of things after i install new lights. the trick is to not tell the car you're not using your foot.
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (06-12-2021) |
Drives: BRZ Limited
Thanks everyone, I will recheck the 4th brake light and test it out. Hopefully that's what's causing it. Will keep everyone posted.
| is it bad to constantly floor the brz? | TheEagle | BRZ First-Gen (2012+) — General Topics | 23 | 02-28-2021 03:45 PM |
| Traction Control Light Constantly On | Cal3000 | Issues | Warranty | Recalls / TSB | 26 | 12-25-2016 05:20 PM |
| Anyone with info on footwell lights that are constantly on? | itsAlex | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 04-06-2016 04:18 PM |
| Automatic headlights constantly on? | Drakelee117 | BRZ First-Gen (2012+) — General Topics | 21 | 08-31-2015 05:26 PM |
| Posts deleted constantly | gmookher | Site Announcements / Questions / Issues | 6 | 12-10-2012 05:06 PM |
