Drives: Honda Insight
Grimspeed Lightweight Battery Mount
https://www.grimmspeed.com/lightweig...caAjMMEALw_wcB
I tried searching to see if someone had used the Grimspeed LWBK in the 86 yet but came up empty handed. It looked straight forward enough dimensions wise to fit and I really like the construction of it so I went ahead and got it. I sort of feel like this is a DIY post but at the same time it's so incredibly easy it's more like an engine mod bolt on than anything else. It does fit securely with relative ease. ![]() First I had to figure out how I wanted to mount it, once I did that I moved it until it rested flush which the mounting hole in the base aligned perfectly on top of this mounting bracket. I drilled it out to fit the original hardware and super glued the oblong nut to the bottom just to hold it temporarily so the bolt can be secured. ![]() Then I addressed my surface rust. ![]() Now with one bolt in place I opted to use a self tapper in the bottom most hole in the top angled bracket. You could just as easily weld a nut or tap the firewall I chose this option for convenience. You can also see there is another mounting point in the bottom of the mount that I did not use but could be as it's a straight shot down into the gap between the wiring harness and the lip edge where the battery sits. ![]() And voila there it is.
| FS: PTUNING Battery Mount + Braille 15LB Battery | skylinekin | Engine, Exhaust, Bolt-Ons | 8 | 06-15-2017 06:26 PM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 12:07 AM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
| Grimspeed Oil Cap and Battery Tiedown | kuhlka | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-10-2013 03:31 PM |
