Drives: Subaru BRZ
Will this setup rub? 17" 7,5 35offset with 255x45
Greetings to all. First time posting. I looked through the Wheel Directory and Fitment Guide Chart
But still could not find firm answers. I have Subaru BRZ 2020, stock suspension with stock: Rims: 17"x7 offset 48 Tires: 215x45x17 I want to buy a better looking rims but choice of 5x100 17" ones in my market is extremely limited and vast majority are 35 offset. Setup I'm thinking about: Rims: 17"x7,5 (or 8 max) offset 35 Tires: 225x45x17 Now I used tire calculators and understand that this setup will poke about 2cm (sorry, I'm metric The question I have is whether or not this setup will rub the fenders on stock suspension? Thanks |
Site Moderator
Drives: ichi 86 Project
Here’s 17x8+35 w 225/45-17 tires. Depends on wheel design, it shouldn’t poke out.
![]() Not a stock suspension, but Cusco struts w Eibach springs giving about 1” drop & as you can see, no rubbing on the fender.
#3 | |
Drives: 2015 BRZ
Drives: Subaru BRZ
Thanks for the feedback. I wander if this setup with +35 offset will put alot of stress on bearings or will it be fine?
Sent from my SM-G998B using Tapatalk |
Drives: 2014 GT86
+35 is not that far off from +48 as some offsets needed for wide-body fitting wheels attrocity. Imho safe enough. Obviously there will be slight load increase on wheel bearings and slight scrub radius increase, but not to killing extent.
| Most "suck" setup | usp2333 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 05-14-2019 10:48 AM |
| WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup | projek_01 | Canada Classifieds | 3 | 03-03-2016 01:45 PM |
| Why a balanced setup is better than a "understeery" setup. | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 07-01-2015 04:36 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
