Drives: 2020 BRZ/86, 2020 BMW 330i
Oil Cooler block off foam
After installing Greddy Oil cooler I can immediately see how effective it is. However, I bought it for track use and drifting, not for daily driving. After looking at the foam inserts that go between the cooler core and the shroud I got an idea of putting a piece of foam inside the shroud for daily driving. Since the cooler gets quite hot, what type of foam should I use?
I can see a lot of upholstery or packaging grade foam that comes in large pieces so it could be easily cut to fit inside the shroud, but is it safe to use near the cooler core or I should use some high temperature foam? |
Drives: Crapcan
TBH I go the lazy route and just zip tie a piece to the grille to block direct airflow. It looks dumb but I don't care. That way I don't have to worry about temp melting it from direct contact with the cooler. It is really only on there for part of the year, once we start averaging over 60-65f I don't really worry about it too much and don't cover it.
That would be my second option. However getting a foam piece would be ideal will look clean.
Drives: Crapcan
Could you use a rubber sheet? EPDM rubber sheets can be bought on amazon and would be fine. Neoprene would also work.
https://www.amazon.com/Non-Adhesive-...540219&sr=8-10
#5 | |
Drives: 2017 86 860 Special Edition
Whatever you stuff within the shroud, unless it's fastened to the end, will end up being pushed by air pressure into the radiator. Last thing you want is to have it melt all over rendering it useless.
Drives: Crapcan
Neoprene is good to 275F, EPDM is good to 300F+. Unless it hits the exhaust it should be fine.
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Consider a thermostat kit long term. Mishimoto offers a thermostatic oil cooler, not sure if the thermostat parts themselves are available
Looking at their kit, I can't tell where the thermostat part is. I'd suspect it is the bit that mounts to the filter mount. I can find kits with them, but cannot find that part as a one off. That's what you need, then you never have to worry at all. |
Back in the day, we used a piece of cardboard -
#10 |
There are a ton of materials that will suffice, I was merely generally cautioning against throwing in random objects. Unfortunately a lot of people have no idea what material properties are or what they actually mean.
#11 | |
Drives: Crapcan
Oh, I gotcha. Sent from my iPhone using Tapatalk
#12 |
Drives: JRSC BRZ SOLD
The GReddy kit comes with a thermostatic plate, no? It seems that for the most part we are reading oil temps post cooler so the internal oil temp can be 15-20F degrees warmer. Aside from winter there may not be anything to worry about.
#13 | |
Drives: Crapcan
Kits with a thermostatic plate still trickle a small flow of oil through the system. I’ve posted in other threads about driving 3 hours in 52f weather and still not getting my oil temp above 140f. Sent from my iPhone using Tapatalk
#14 |
30 minute maintenance
Drives: My18 wrxsti
I use a 2mm thick peice of black corflute with 2 velcro tabs fixed with 3m double sided tape. The corflute has creases so it folds and slides through the grill. Regardless of where the temp is read it was read there before the oil cooler install. So with the cover I`m seeing standard oil temps for daily use now. My SP is thermostatic.
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
| WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 05:21 PM |
| WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 06:48 AM |
| Foam guns | sa1126 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 11-07-2012 10:01 PM |
| Foam Gun: Necessary? | Re~Mix | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 15 | 06-24-2012 10:45 PM |
