Old 05-12-2021, 02:42 PM   #1
DrunkParadox
Drives: 2014 Scion Fr-S
Underglow
I'm relatively new to this, but I'm trying to do underglow and the kit I got can be wired to the interior fuse box but I don't know how to get from there to underneath the car. Any clues? Also don't know where to hide the wires out of the way😅
DrunkParadox is offline   Reply With Quote
Old 05-12-2021, 03:54 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Originally Posted by DrunkParadox View Post
. . . wired to the interior fuse box but I don't know how to get from there to underneath the car.
Welcome to the forum, DrunkParadox!
In the engine compartment between the brake booster and the fender is a rubber grommet that passes wiring through the fire wall. There is a rubber "nipple" sticking out. Use a side cutter or similar to remove the end of the nipple and you will have access to the interior very close to the fuse panel.
LimitedSlip is offline   Reply With Quote
Old 05-12-2021, 05:16 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i normally just use a razor blade and cut an 'x' in the grommet to the side of the main harness, just barely the size of the wire i need to push through, and the grommet still seals around it.
Old 05-21-2021, 07:58 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Upvote for this method.
lighting, underglow
Underglow recommendations? JakeRogue Cosmetic Modification (Interior/Exterior/Lighting) 8 04-11-2021 08:43 PM
Underglow? bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 67 09-04-2014 07:30 PM
To underglow or not to underglow that is the question. cjsporl1996 Cosmetic Modification (Interior/Exterior/Lighting) 85 03-18-2014 03:55 AM
Underglow Signal Kit FRSTRM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 05-18-2013 01:59 PM
