Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
FOUND - Close
FOUND
Drives: BRZ Limited
Unless you don't care about aesthetics, I would get new. It is a pretty tight fit, so once the gauges are on there, it's a bit tough to remove. Used ones will have gouge marks and scratches on the edges/rims from prying out the old gauges.
#3 | |
Off to the track!
Drives: BRZ Limited
Yeah, they respond to every WTB posts. I have the dual block8head vent gauge and I had to take out the gauges at one point and now there are scuff marks and small gouges on the edges where you'd pry it from. I also tried to buy used at first, but used ones had the same scuffs/scratches. They're not really noticeable, but at least you can take comfort in that fact that when you buy new, it'll be blemish-free.
| The Following User Says Thank You to nwgabrz For This Useful Post: | villainous_frx (05-12-2021) |
Drives: Crystal White BRZ
I have a new one coming & im currently using a used one I bought from a member here. I’ll let you know when it comes In & sell you the used ? I’ll keep you posted
Off to the track!
Drives: 2016 Scion FRS Release Series 2#439
If that^^^falls through I have new one purchased from a US member who had a change of plans. I’m in Burlington, ON.
Off to the track!
| Block8Head Gauge Pod | YamahaR86 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-14-2019 03:55 PM |
| block8head single gauge pod | peaches | Interior Parts (Incl. Lighting) | 1 | 06-04-2019 11:28 AM |
| BLOCK8HEAD gauge pod? | batlwagn | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 10-11-2016 08:05 AM |
| FS: Vent Gauge Mounts - ATI & Block8Head | FR-Shred | Interior Parts (Incl. Lighting) | 2 | 05-07-2016 06:30 PM |
| WTB: Block8head Vent Pod (60mm) | Xiao Li | Want-To-Buy Requests | 0 | 09-25-2015 01:07 PM |
