Old 05-04-2021, 04:29 PM   #1
Mizuiro
Mizuiro's Avatar
Drives: Brz
Finding the trunk part number without holes from factory
I'm trying to find the correct trunk part number without spoiler holes in them. I have a pre-facelift zenki model (2015) and I want to fit the JDM Ts spoiler on it. Having the holes fixed at a body shop is way more expensive than just buying a new trunk and having it painted.
There's only like 66 BRZs (in total!) here in Holland and the Subaru technicians that I spoke to said that the BRZs here always come with the spoiler.
So, does anyone know the correct trunk part number without spoiler holes? I've also called Toyota and I have been given SU00301454 and SU00306402 but the technician doesn't know which one has holes or not. (Assuming both Subaru and Toyota trunks are the same..?)
Also I know that the kouki models (2016+) have reinforced trunks. If I'm going to get a new trunk, might as well order that one instead right?
Mizuiro is offline   Reply With Quote
Old 05-04-2021, 05:01 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
This came from subaruparts.com/body
BigTuna is offline   Reply With Quote
Old 05-04-2021, 06:38 PM   #3
Mizuiro
Mizuiro's Avatar
Drives: Brz
Oh man, thanks so much! Found that this is the zenki one.
Old 05-04-2021, 07:35 PM   #4
Mizuiro
Mizuiro's Avatar
Drives: Brz
The more I research about the trunks, the less I understand about the codes that comes after CA.. There seems to be sooo many different trunks. And yet they all look almost the same.
Old 05-05-2021, 07:38 AM   #5
Mizuiro
Mizuiro's Avatar
Drives: Brz
Think I found it, the facelift model Subaru's will always have holes in them.
https://media.subaru.com/pressreleas...017-subaru-brz
New pedestal-type aluminum rear spoiler, standard for all trims, improves downforce; comes in matching body color and black finish.
I've confirmed with Toyota that they have a 86 trunk without spoiler on the facelift model and uses the code SU003-01454. Since they look the same, I'd reckon that this will fit the BRZ just fine.
Old 05-05-2021, 08:10 AM   #6
BigTuna
BigTuna's Avatar
The original numbers I posted was for a 2013. I just changed it to a 2016 and it came up with the results below. Maybe this is what you're looking for.
57509CA0909P - without spoiler
57509CA1019P - with spoiler
Help finding part number Sliver_bullet Engine, Exhaust, Transmission 1 11-10-2019 12:07 AM
Looking for trunk part number gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 0 12-10-2018 12:49 AM
Neec help finding the right part number QTR FMS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-11-2018 12:54 AM
Trunk Unlock Part Number pseudo Cosmetic Modification (Interior/Exterior/Lighting) 5 11-03-2014 11:35 AM
Need help finding a part number xbb1024 AUSTRALIA 4 07-31-2014 07:55 AM
