Old 04-28-2021, 09:47 AM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
Track Pads and Fluids for a Trackcross???
So I wanted to get your thoughts.
So I have XP10 and 8's Motul 660 that I was gonna throw on this weekend ahead of the Trackcross event on the 15th of May. Then I got to thinking... Is it really necessary to put full on track pads and high temp fluid yet for a Trackcross?
Granted I've never done a Trackcross but doing one lap with long breaks in between I would imagine your brakes would never really heat up enough... But again... I've never done one.
Should I just throw the brakes and fluid on now or wait for my next HPDE which is on the 17th of June?
Jstyle is offline   Reply With Quote
Old 04-28-2021, 01:40 PM   #2
strat61caster
strat61caster's Avatar
I autocrossed my XP10's a few times, they're good, you'll be happier to have them and not need them then not have them and then need them. I've faded some spongy street pads at high speed hot summer autocross. It will really depend on how the track cross is set up.
Fresh fluid never hurts and it's not that expensive, waiting a month won't mean much if you flush yearly/in the off season. If you cook the pads you'd probably cook the OE fluids as well.
ineedyourdiddly
Old 04-28-2021, 01:51 PM   #3
Jstyle
Jstyle's Avatar
Drives: 2020 86
I should have also caveated it with the 86 has 472 miles on it
Old 04-28-2021, 02:10 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've never needed anything other than off-the-shelf name-brand parts-store DOT4 or DOT5.1 in any car i've tracked, including ~550hp 6.8 liter FD...
Might as well run the track pads if you have them, I've never run factory pads on my BRZ at the track but magazine tests have complained about them (Lightning Lap one year?). IMO better to run same pads front/rear on this car, but not a big deal in this case I don't think...
Old 05-09-2021, 01:05 AM   #5
jflogerzi
jflogerzi's Avatar
Carbotech xp10 are not good on the street. The squeal really bad. On track they are great
2013 Series 10 FRS #553
2020 Autocross/Trackcross Schedules JakeRogue Mid-Atlantic 1 01-26-2020 07:49 PM
2018 Autocross/Trackcross Thread (Washington DC Area) JakeRogue Mid-Atlantic 47 11-15-2018 10:29 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
Pads/ Fluids Question JGalp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 08-01-2016 05:40 PM
ProPartsUSA.COM Stoptech BBK|Pads|Rotors|Lines|Fluids ProPartsUSA Brakes, Suspension, Chassis 1 07-17-2013 07:15 PM
