Old 04-23-2021, 05:20 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Looking for OEM style black lug nuts
I can't believe I'm actually posting about lug nuts, but am having trouble finding what I'm looking for. For years I've been using silver lug nuts from The Tire Rack that came with my aftermarket wheels. They've been fantastic. I think they're just OEM-style, possibly made by McGuard. They are not spline drive lugs. I'd like to find more of what I already have, but in black. As they are run year-round in Colorado, they should be closed-ended. My studs are of OEM length, but ARP.
Are these Gorilla nuts what I should buy? What else should I consider?
TIA
Old 04-23-2021, 07:47 PM   #2
Transport3r
Drives: -
The closed end gorillas are solid lugs, they look good and keeping the threads clean was not a problem, and the knurled tip is nice to get them finger tight. I had them for ~3 years, they do get some surface rust where the wrench mars them after a while.
Transport3r is offline   Reply With Quote
Old 04-26-2021, 11:26 PM   #3
jflogerzi
jflogerzi's Avatar
This is what I run and they have been solid for a few years
https://www.ftspeed.com/part/85-pare...ended-lug-nuts
2013 Series 10 FRS #553
Old 04-27-2021, 03:23 PM   #4
Grady
Grady's Avatar
I have been happy with these.
https://www.amazon.com/Gorilla-Autom...motive&sr=1-11
Old 04-27-2021, 03:27 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks guys. Those are both spline drive, which I dislike. I ordered the ones in my original post.
Old 04-27-2021, 04:22 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've had the same set of gorilla forged lugs about a year. They hold up well so long as you don't chip the paint finish.
To give you an idea how they poke on stock wheels. I run them with ARP extended 2.5".
720 Form GTF1 Wheels, stock lug nuts or tuner style? 85258 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-15-2020 10:28 AM
WTB: Black Lug Nuts Just Drive Canada Classifieds 5 10-22-2018 09:18 PM
FS: Black open ended lug nuts skylinekin Wheels and Tires 7 09-11-2018 12:48 AM
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 09:47 PM
Black Steel Lug Nuts AlexK Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-16-2014 10:28 PM
